Filters
Discussion in 'Film Discussion and Q & A' started by bemmermazda, Sep 23, 2007.
  1. bemmermazda
    bemmermazda TPF Noob!
    Sep 22, 2007
    121
    Hello,
    Im looking for some filters, mainly polarizing and ND. I have telephoto and wide angle. Wide angle is 55mm and the telephoto is 58mm. That is my problem, filters are expensive and i do not want to buy two of all filters. Any solution to this?
  2. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    Just buy a filter with the biggest thread (58mm in your case) and buy some step-up rings (or step-down, cant remember what its called, something like that though)
  3. simonkit
    simonkit TPF Noob!
    Dec 30, 2006
    238
    21
    North Wales, UK
  4. Bobby Ironsights
    Bobby Ironsights TPF Noob!
    Dec 3, 2006
    331
    12
    Thunder Bay, ON, Canada
    Do you have ZOOM lenses!??! If so, I'd be more worried about that low light shot you asked about earlier. When I said a "normal" lens, I meant a normal lens, which is photo-speak for a 50 mm prime (non-zoom) lens.
    It's called a normal because 50 mm focal length on a 35 mm camera gives a perspective which is most similar to what a human eye would see at that same spot. A shorter focal length gives fish-eye wide-angle, and a longer F-length gives a flattened telephoto perspective.
    Prime lenses have fewer lens elements than an equivalent zoom lens, so they let in more light, and are "faster", and have substantially better low light performance.
  5. bemmermazda
    Sep 22, 2007
    121
    i have a 300mm but mainly use my 28-80mm. I assume that will be alright.
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    One train of thought is that if you have good glass, even so-so glass, why would you put inferior plastic in front of it?
    As "doenoe" said, you can buy for the largest filter size lens you have and then get the step-up/down adapters.
