Final Lens Choice
Discussion in 'Photography Beginners' Forum' started by AlexColeman, Feb 14, 2009.
  1. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    I am going to replace my 16-85 zoom with something alittle better. I am looking at 17-55, 24-70, and any third party zoom. I might be upgrading to FF in a year or two. Any comments or help with me making a decision?
  2. AlexColeman
    Dec 13, 2008
    1,732
    36 views and no comments on any of these lenses? ;)
  3. vabikeguy
    vabikeguy TPF Noob!
    Feb 14, 2009
    32
    Winchester, VA
    Maybe people thought your post was more of a statement as opposed to a request for advice?
  4. AlexColeman
    Dec 13, 2008
    1,732
    Nope, I intended it as a request for comments on these lenses in order to help me make an easier decision.
  5. Tighearnach
    Tighearnach TPF Noob!
    Oct 26, 2007
    224
    Hi
    I think you need to decide on whether or not you will go FF. That will answer which lens you should get. Both are supposed to be excellent. If you can't decide that might warrant buying the cheaper 3rd party lens. I have the Sigma 18-50mm f2.8 and think it's excellent. Tamrons is supposed to be of very high quality too.
  6. LiveWave
    LiveWave TPF Noob!
    Jan 2, 2008
    57
    If you plan to go FF, then go with the 24-70, however if you do go that route, just keep in mind your 24 will be more like a 36. Though 17-55 will still probably resell fine since DX and crop sensors will probably not be going out anytime soon.
  7. AlexColeman
    Dec 13, 2008
    1,732
    Can you clarify your statement? If I go FF, won't it just be 24? The question I guess I am asking is whther to go with 24-70 or 17-55 and why.I know the 24 isn't wide, but is it ok?
  8. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    24 is pretty wide on a full-frame.
    Consider primes (zoom with your feet), which have much better image quality and simplify the art when actually taking photographs (i.e. you don't spend time zooming in and out trying to compose correctly, you just know what the view angle is going to be and you take your pictures based on that).
  9. AlexColeman
    Dec 13, 2008
    1,732
    Yeah, but that guy says the field of view will be like 36 on FF, which isn't correct. So, is the 24-70 a good choice?
  10. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    The 24-70 - Nikkor? Much better choices (that will still offer full frame support) than that pro piece of glass. If you absolutely MUST have the best, by all means go for it - but sheesh, are you going to be doing any pro work with this?
    As for the 24/36 - he means on the D300. But such comparisons are meaningless if a person has never seen 24 or 26 on a full frame or 35MM film camera.
  11. AlexColeman
    Dec 13, 2008
    1,732
    Yeah, but I got a substantial amount to put to lenses, so why not get the best as an investment?
    Other than that, it will be the best choice?
  12. ANDS!
    Nov 14, 2006
    2,178
    Downtown
    An investment in what? Lenses aren't like camera bodies in that you can be justified in paying for the premium bodies and get the premium utility out of it. The lens is either good or it aint. The 24-70 F/2.8 Nikkor is good, but its not 1000 dollar good. Is it worth (construction wise) 1000 bucks. Maybe. Some will say "well I like a sturdy well built lens" - at the end of the day if you drop any lens you're pretty much f'd. So then the question becomes - why do I REALLY want the higher priced lens. They are rated very well - but that does not mean the 3rd party lenses arent.
    For example, you might have the 24-70 F/2.8 from Sigma rated at 8.6 or so on Fred Miranda, and the Nikon equivalent rated at 9.4. So, you've got the 1700 for the Nikon, compared to the 300 bucks for the Sigma. Essentially having you forking out 1400 dollars for 0.8 bit of quality difference. A lens that will still be forced into DX mode on a full frame camera (same with the slightly less ridiculous but still priced 18-55).
    So. Long story short. Its your money - spend on it what you will. But! Take a very long inventory of the reasons behind these decisions and whether you are buying into the hype, or really REALLY find your shots "suffering" under the constraints of lesser (read: cheaper) lenses.
