First attempt at glamour
Discussion in 'People Photography' started by Tantallonrox, Nov 20, 2007.
  1. Tantallonrox
    Tantallonrox TPF Noob!
    Oct 5, 2007
    81
    Ohio
    Trying Glamour type photos. This is one I shot the other night. I'm looking for C & C on the PP. I have also posted the original to make it easier to compare. Thanks for looking.
    The original
    [​IMG]
    The PP
    [​IMG]
  2. Tantallonrox
    Oct 5, 2007
    81
    Ohio
    Yikes!!! after seeing the side by side, I WAY over did the eyes:spank:
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Yikes is right!!
    I think you need to think more in terms of reshooting than salvaging something like this. There might be alot of post production used in modern fashion/glamor, but you still need everything perfect for it to work right.
    Try having her stand, make her back straight, make her twist her body a wee bit to make her body into an S-shape and have her tilt her head back a little bit to accentuate her neck.
    Use more lights, and reduce the background to something less complicated as to not distract from the subject. Something middle gray with a gradient feathered onto it, think white seamless with a background light, hair light, key light, and fill light (minimum). You can have the hair light be the background light and hair light if you feather it off right.
    Have her wear something high-end with a ridiculous amount of exotic looking makeup on and hair that's has had 3 hours spent on it. She needs to look technically flawless. Diffused light sources make this much easier, specular light sources bring out texture and specularity in subjects.
    Ditch the mens dress shirt, undone tie, plaid skirt, and stockings combination. It looks trashy, and I doubt that's what you were trying to go for.
    Try this and I guarantee your images will look 100x more like fashion/glamor work.
  4. Tantallonrox
    Oct 5, 2007
    81
    Ohio
    Thanks for the comments. I will deffinately try a reshoot using your suggestions. Lighting I am limited on. I have 3 work type lights and that is it, but I will attempt to use them all. Thanks again.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Fill cards and reflectors can give the illusion of multiple lights.
