first attempt at star trail photog
Discussion in 'General Gallery' started by AF44, Jul 11, 2008.
  1. AF44
    AF44 TPF Noob!
    Aug 27, 2007
    218
    Orange County California, USA
    took this one in lake powell, utah
    16 minute exposure, 400 iso, 18mm, f:4.5
    [​IMG]
    tell me what you think!
  2. BoblyBill
    BoblyBill TPF Noob!
    Oct 30, 2006
    2,860
    37
    in the eye of a tornado
    All I see is a red X... :(
  3. dry3210
    dry3210 TPF Noob!
    Jun 11, 2008
    546
    6
    Hatboro, PA
    Thats pretty crazy. I assume a run of the mill lens wouldn't be able to pull this off?
  4. motorshooter
    motorshooter TPF Noob!
    Jul 5, 2008
    157
    Commonwealth of Virginia
    What are the sqwiggly looking lines near and intersecting the brighest star?
  5. AF44
    AF44 TPF Noob!
    Aug 27, 2007
    218
    actually this is with the stock lens on the camera... the squiggly lines in the pic are me trying to get the camera where i want it when the shutter is open... or aliens!
  6. toofpaste
    toofpaste TPF Noob!
    Jul 11, 2008
    1,202
    Earth
    Aliens sounds like the logical choice.
  7. Scott7117
    Scott7117 TPF Noob!
    Jan 30, 2008
    70
    Wow cool shot! I've never been able to get very good results with star trails.
    The only thing that bugs me is the amp glow in the top left, but I suppose there's nothing you can do about that. I'd also recommend bumping the ISO down to it's lowest setting.
    Thanks for sharing! :)
  8. Easy_Target
    Easy_Target TPF Noob!
    Aug 4, 2007
    380
    I would've done it at the lowest iso possible.
    You assume incorrectly. You can do it just about anywhere if you have a tripod, cable release and little to no light pollution *cough* NYC *cough* or hazy skies.
  9. astrostu
    astrostu Guest
    You'd also probably not want to do this when the Milky Way fills a significant part. Because you're doing trails, the Galaxy just looks like a broad, fuzzy cloud that - to me, at least - interferes with the rest of the composition.
    A shorter exposure and/or lower ISO would help reduce the magenta glow in the upper left.
  10. invisible
    invisible Been spending a lot of time on here!
    Mar 10, 2007
    5,213
    977
    Canada
    The magenta glow is probably the sensor getting hot. Try shorter exposures (maybe not longer than 10 minutes), with low ISO.
  11. AF44
    AF44 TPF Noob!
    Aug 27, 2007
    218
    thanks a lot for all the replies next time i will try a lower iso and not pointing it at the milky way and see what kind of results i get
