First attempt with the Flash
Discussion in 'Critique Forum Archives' started by danalec99, Sep 27, 2004.
  1. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    I have always been uncomfortable in using the on board flash on 10D as it usually delivered a 'cheap' lighting. But in certain environments (like for the engagement that I attended on Saturday morning), I have found that one cannot always expect windows everywhere. There wasn't even one window at the reception hall and most of the shots that I got were fuzzy. Therefore, the need for effectively utilizing the flash evolved. I know I will have to invest in something like 580EX/Strobes down the line but I thought of starting out with the on board flash. If practiced well, I think it is good for close-up shots.
    This is the first attempt from last night. Inputs and suggestions are most welcome.
    Thanks in advance.
    [​IMG]
    [​IMG]
  2. Sharkbait
    Sharkbait TPF Noob!
    Nov 4, 2003
    2,405
    18
    Indianapolis, IN
    For on-board flash, these aren't bad. I tell ya what though, one of the best investments I've made so far has been the $300-something I put into my speedlite 550EX.
    For that 2nd photo, the pose and expression is great, but there are some hotspots that you might try to burn/heal in photoshop. Also, because that on-board flash tends to wash out so much color and life, I might just convert these to b&w and boost up the contrast some.
  3. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    This is defenitely a wallet burning hobby :)
    Thanks Shark for the input.
  4. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    You can really tell that the on-camera flash was used...especially in the second one. There are hot spots all over her face.
    I don't know the 10D, but could you have adjusted the flash compensation to -1 or something?
  5. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Yes, I could and I did try a handful of + and - with more frames. But the frames which were technically okay had bad expressions, so I had to discard it. Will try more.
    Thanks Mikey for the input. I dislike the flash effect on the subject. Don't prefer to drench the center of focus with light.
  6. Sharkbait
    Sharkbait TPF Noob!
    Nov 4, 2003
    2,405
    18
    Indianapolis, IN
    I think most of those hotspots could be cleaned up in PS. It'd be worth a shot anyway.
  7. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Do you usually use the clone stamp for these sort of clean up jobs?
  8. Sharkbait
    Sharkbait TPF Noob!
    Nov 4, 2003
    2,405
    18
    Indianapolis, IN
    You can use that or the healing stamp. If you use the clone stamp, feather the edges out quite a bit. You can also try using the burn tool to darken those areas some. But to truly cover them, yeah healing patch or clone stamp.
  9. crystalview
    crystalview TPF Noob!
    Sep 2, 2003
    360
    Minneapolis, MN
    I will have to say that you can really tell the difference between an on-board flash and a speedlight flash. I was afraid to use my on-board because the results were not satisfying. I just picked up an sb-600 for my D70 and it does wonders. The TTL mode basically takes the picture for you.
    If you can afford it, get a strobe/speedlight. They are unreal.
    You could touch that up in PS, but its so nice to NOT have to do that, and just use what came right from the camera. In my opinion.
  10. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks Shark, crystalview.
    Are you well versed in PSCS? Is their tutorial helpful??
  11. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    [​IMG]
    I did not attempt to heal the hot spots . Just converted to BW, played with the Brightness/Contrast.
  12. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    The thing that is bothering me the most with the photos, is that the white balance looks off in the background. It's got a slight yellow cast to it, which would be fixed once you get that bigger flash)
