first HDR, question about clouds
Discussion in 'Beyond the Basics' started by phogan22, Jun 11, 2009.
  1. phogan22
    phogan22 TPF Noob!
    Jun 20, 2008
    46
    Bethesda, MD
    So this is my first HDR shot, I'm still experimenting with trial versions of various programs, like Photoshop CS4 and Photomatix Pro, and I have to say that the Photomatix version is my favorite so far. However, I still wonder about why these dark shadows that don't really look natural at all appear over some of the darker parts of the clouds. It also happens occasionally on the highlights. Any comments would be welcome.
    Thanks!
    ~Paul
    [​IMG]
  2. MBasile
    MBasile TPF Noob!
    Apr 30, 2008
    362
    Sunnyvale, CA
    It looks to be the result of the clouds moving between frames
  3. phogan22
    phogan22 TPF Noob!
    Jun 20, 2008
    46
    Bethesda, MD
    I know what you mean, but they weren't taken that long apart. Also, it doesn't look so much like the ghosting that I've found in other shots
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I find photomatix tended to do this when across all of the source frames some data was still clipped. Could that be the case here?
  5. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    It's hard to tell from the size, but it also looks like your exposures may not have been lined up right?
  6. phogan22
    phogan22 TPF Noob!
    Jun 20, 2008
    46
    Bethesda, MD
    Thanks, I did check and the camera shifted horizontally very slightly in between shots. That is very probably the problem (also because I have a pretty cheap tripod :\ )It also happens occasionally in the brightest highlights, like if there's a particularly bright patch of clouds. Not sure if it's the same cause but I'll look into it.. Thanks!
    -Paul
  7. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Maybe you just need more difference in the EV between shots...Just a thought. I'm not proficient with HDR (yet).
    Try using a cable release to reduce the amount of movement between shots. They're so cheap, everyone should have one.
