First Light box attempt help
Discussion in 'Photography Beginners' Forum' started by alarionov, Mar 3, 2009.
  1. alarionov
    alarionov TPF Noob!
    Jan 11, 2009
    292
    Beaverton Oregon
    Ok so thought I would try with a DIY lightbox but had the most difficult time getting it bright enough. Still had to brighten it in PP but cant seem to get it white, its a bit yellowish.
    1 1/60" F14 Iso400 WB set to tungsten on both
    [​IMG]
    2 1/15" F22 Iso 400
    [​IMG]
  2. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It's most likely a metering issue. What the camera sees is a whole lot of white...so it gives you settings to make it mid toned (18% grey). The camera always does this because it is programmed to think every scene is 18% grey. But when you scene is mostly white the meter is tricked so you can't trust it. You need to add exposure to brighten it up. It's as simple as adjusting you EC (exposure compensation). I'd suggest adding one whole stop to start with...and go from there.
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    What is the setup? What kind of lights are you using?
    What kind of material did you use for the translucent part of the light box?
    Are you shooting using one of the Creative Modes or are you shooting in full manual?
  5. alarionov
    alarionov TPF Noob!
    Jan 11, 2009
    292
    Beaverton Oregon
    this is the one I did
    How to Make An Inexpensive Light Tent - DIY
    but I set up two clamp on lights from the sides.
    I used shutter priority in this instance
  6. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    For these kinds of shots I go full manual on my XTi and do lots of test shots and checking of the histogram. I don't use constant lights, I use remote Speedlites on light stands. I plan to get a Sekonic L-358 Flash Master light meter in the near future to help simplify things a bit.
  7. alarionov
    alarionov TPF Noob!
    Jan 11, 2009
    292
    Beaverton Oregon
    thanks for the help, I will try adjusting the exposure compensation.
  8. alarionov
    alarionov TPF Noob!
    Jan 11, 2009
    292
    Beaverton Oregon
  9. Don Kondra
    Don Kondra Been spending a lot of time on here!
    Dec 11, 2007
    1,518
    620
    Saskatoon, Saskatchewan, Canada
    Try Aperture mode @ f8... are you using 5500k lights?
    Get them here
    Cheers, Don
  10. alarionov
    alarionov TPF Noob!
    Jan 11, 2009
    292
    Beaverton Oregon
    thanks for the advice I will give it a try. Currently I am using cfl thats only 4100 kelvin I will definitely try a higher kelvin bulb though.
  11. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    The bulbs shouldn't be an issue, as long as your lighting is consistent....because you can adjust your WB to suit.
    If you aren't already, shoot in RAW mode. This will allow you to adjust the White Balance on the computer, after the shot has been taken.
  12. Parkerman
    Parkerman TPF Noob!
    Jan 10, 2008
    982
    North Alabama
    What I always did using my light box was I preset the WB myself.
    When i set the preset WB.. I just made sure the box was empty and I was just taking pictures of the white.
    Most of the time my shutter speeds were pretty slow. So.. you need to be using a tripod for sure.
    *edit*
    and even on some of mine.. the white could have been brighter as it was a tad bit gray.. here are some that I took back towards the beginning of last summer
    http://i15.photobucket.com/albums/a392/Parkerman/Photography/DSC_1989.jpg
    http://i15.photobucket.com/albums/a392/Parkerman/Photography/DSC_2024.jpg
    http://i15.photobucket.com/albums/a392/Parkerman/Photography/DSC_1964.jpg
