First Macro Attempt-Orchid
Discussion in 'Nature & Wildlife' started by Graelwyn, Jun 18, 2008.
  1. Graelwyn
    Graelwyn TPF Noob!
    Jan 6, 2007
    181
    Please bear in mind I have not done this before, and this was very much a spur of the moment thing... without using a proper background or separate flashgun. Handheld.
    [​IMG]
  2. tb2
    tb2 TPF Noob!
    Feb 16, 2006
    971
    OK for a first attempt. On the next shot I'd look to make sure that the only OOF element wasn't near the centre of the composition. It helps if the background colour complements the main subject, but given the way you describe you took the shot, you accepted what was there. If/when you use an on-camera flash try bouncing it from the side with a reflector (white card is good enough) on the other side to reduce the darkness of the shadows. I find you can do a lot with that simple set up.
    Regards, Tony
  3. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    Good advice tb2,
    Pretty image colors! I bet the textures look awesome at full res.
