First moon shot!
Discussion in 'Nature & Wildlife' started by Big, Aug 1, 2009.
  1. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    First moon shot with my new DSLR. I know everyone's probably seen 1,000,000 moon shots but here's one to make it 1,000,001. Took a few tries to get it right but I think I nailed it. I wish I had a 400mm instead of a 300mm but luckily the massive crop didn't lose any detail really...
    [​IMG]
  2. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    You should dramatically decreasing the f/# to at a maximum f/8, possibly f/9.6 with your f/4-5.6 lens. Keep the shutter speed about the same and see what it looks like - you may have to decrease it a bit to 1/200 or 1/250, but nothing shorter, as this image you posted is pretty dark.
  3. Chris Mccomas
    Chris Mccomas TPF Noob!
    Aug 3, 2009
    19
    Dundas ontario
    the moon can be such a difficult thing to shoot sometimes
  4. PushingTin
    PushingTin TPF Noob!
    Apr 23, 2007
    458
    17
    South Africa
    For a first moon shot you have done really well, my first moon shot didnt look half as good as yours...
    BUT I dont think you nailed it, its very soft IMO...
    Now please dont get me wrong, I am no expert on moon photography but here are 2 examples of what I took. Second one may be overprocessed / sharpened / noisy but just compare yours in terms of softness.
    [​IMG]
    [​IMG]
    I like to actually see the craters on the moons surface.
  5. Yasa
    Yasa TPF Noob!
    Aug 3, 2009
    48
    Calgary, Alberta, Canada
    Pretty good, but I agree with PushingTin in that it is too soft. I've never been able to capture the moon properly though, so good work thus far!
  6. EricD
    EricD No longer a newbie, moving up!
    Feb 25, 2008
    1,660
    194
    Geneva, Florida
    Nice shots by both of you.
    Pushing Tin.....first shot is awesome and tack on but the second one is way over sharpened (in my opinion)
  7. RichA
    RichA TPF Noob!
    Aug 3, 2009
    7
    1. Shoot when the Moon is as high in the sky as possible to avoid atmospheric effects.
    2. Try to avoid shooting over rooftops, paved areas due to heat waves.
    3. If you use a large lens/telescope, let it reach outside temp before shooting, this applies especially to mirror lenses.
    4. Use whatever method you camera allows to dampen vibrations. Mirror lock up, whatever. Use a self-timer or remote release, do not touch the camera.
    5. Expose the Moon about 1.3 stops over because it is mostly white.
    6. Use a shutter speed fast enough to overcome the rotation of the Earth. This speed increases with focal length used.
    7. Use the longest focal length you can to make sure the image is as large as possible while making sure the atmospheric conditions (steadiness, do the stars twinkle, if so, it's not steady) will support it.
