First photo, what Should I work on?
Discussion in 'Photography Beginners' Forum' started by Velton30, Dec 8, 2008.
  1. Velton30
    Velton30 TPF Noob!
    Dec 8, 2008
    23
    The title says it all. Brand new to SLR and this was one of my first shots outside my house. What should I work on in this close up.
    I am just using a +3 magnifier on the lens (18-55MM)
    P.S. Don't get to technical on me ;) I am still reading the book.
    P.P.S. I don't think my picture is posting =/ Will try and edit if its not posting.
    [​IMG]
    http://www.flickr.com/photos/velton30/3093415103/ HEre is a link
    [​IMG]
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    The first thing that I would do is work a bit on composition... you don't generally want a subject dead center in the frame like that. If it is OK to edit your picture I will show you a different composition for this picture that you might like.
  3. Velton30
    Velton30 TPF Noob!
    Dec 8, 2008
    23
    I don't mind if you edit feel free.
    And thanks
  4. sabbath999
    Apr 11, 2007
    2,700
    68
    Missouri
    I used the "rule of thirds" to crop your shot...
    Rule Of Thirds
    What do you think?
    [​IMG]
  5. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,154
    927
    Woodbridge, Ontario, Canada
    Always try to keep the head in focus.
    Try not to shoot behind the animal ... unless the angle adds to the topic.
    Yes, composition is the thing to work on.
    Rule of Thirds is always an easy way.
  6. Velton30
    Velton30 TPF Noob!
    Dec 8, 2008
    23
    Thanks sabbath999 I do like that, and you reminded me of a 10th grade high school photo class "Rule Of Thirds" lol.
    I also see what your talking about dxqcanada when you say focus on the head. Now I see I am looking at its rear end instead of the head.
    Thanks a lot guys!
  7. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    Also were you using auto focus? for macro work like that bee its far easier to work if you use manual focus - set the lens to its closest focusing distance and then manually move the camera and lens closer to get focus. Rocking a little back and forth once you are really close to get the focus right where you want it.
    You caught the shoulder of the insect this time - idealy you want the eyes - though at this angle it would be tricky.
    Also don't be afraid to use your flash - with macro work its very advisable to do so - just hold a few folds of white toilet paper infront of the flash (use some elastic bands, just make sure they don't cover the flash head) which will help lessen the harsh effect of the flash light.
    With that in use read up on aperture priority mode - when in that mode set your f number to something large - f8-f16 (f13 is where I generaly sit with mine). This is closing down the aperture (a bigger f number means a smaller aperture is used - and thus also a smaller apperture means a bigger f number - hence using a bigger number is closing down the aperture - making it smaller). A smaller aperture means that you get more depth of field in a shot (ergo more of it is in focus).
    Of course a smaller aperture also means that you let less light into the camera - so your shutter speed is slower to compensate - using flash counters this and means you can use smaller apertures with faster shutter speeds (and thus get more depth into a shot0
  8. Velton30
    Velton30 TPF Noob!
    Dec 8, 2008
    23
    Overread thanks for using the simple terms, I actually understood that and i will take it into account next time.
    I am starting to learn how to use the P,A,S,M modes and trying to avoid auto so I can learn.
    Back to the book!
  9. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    Focus on aperture priority mode first - its a very popular and diverse mode and many people use it a lot. As aperture directly controls depth of field and the auto shutter speed selection adapts to changes in lighting quickly its very popular with people who have to shoot moving subjects or when out and about walking.
  10. jwsciontc
    jwsciontc TPF Noob!
    Sep 23, 2008
    531
    Trumbull, CT
    i like how it was edited above with it off to the right, but i would have gotten the entire flower on the right in the frame, and the head in focus as stated.
  11. sabbath999
    Apr 11, 2007
    2,700
    68
    Missouri
    Keep in mind that with something like a bee, they are crawling all over the place or flying, so framing is tricky... it helps to get what you need in focus if you use a small aperture (f/22 for example, or smaller if you can) when shooting close up.
  12. thereforeiamx
    thereforeiamx TPF Noob!
    Aug 20, 2007
    134
    nyc<3
    the crop is much better. also, don't just shoot one. shoot continuously. insects are always in motion and you are always in a spot to get a much better shot/pose when it's on the move :)
