Aivariukas
- Joined
- Apr 30, 2017
- Messages
- 8
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
What do you mean about that?the biggest fault lies with the backgrounds. So work on seeing the backgrounds
Yeah, I'm using D40, but my lens are 35-70...you're shooting a D40 and I going to guess you have the 'kit' 18-55 lens
What is that?doesn't dip below f/3.5
Learn to see the entire composition, realizing that the background is also a part of the photograph. Find a position or camera angle to minimize distractions seen in the backgrounds.What do you mean about that?the biggest fault lies with the backgrounds. So work on seeing the backgrounds
Actually, I still can't understand what's wrong for example in photo no.2 ... because for me, all these photos are good... Can you send me some examples?Learn to see the entire composition, realizing that the background is also a part of the photograph. Find a position or camera angle to minimize distractions seen in the backgrounds.What do you mean about that?the biggest fault lies with the backgrounds. So work on seeing the backgrounds
The 'f' setting is the aperture. This is an adjustable circular diaphragm that allows more or less light onto your sensor (or film in the old days). When the "hole" is wide open, you have a small 'f' number and a small area of focus. Things in front your your subject and behind your subject will be blurry. When the 'hole' is shut down tight, you will have a large 'f' number and a much larger area in front and behind your subject that is in focus.What do you mean about that?the biggest fault lies with the backgrounds. So work on seeing the backgrounds
Oh.. Now I understand much better, but I also have some question... My camera is not too old? and is it good for beginners? Cause, I don't know a lot about cameras...The 'f' setting is the aperture. This is an adjustable circular diaphragm that allows more or less light onto your sensor (or film in the old days). When the "hole" is wide open, you have a small 'f' number and a small area of focus. Things in front your your subject and behind your subject will be blurry. When the 'hole' is shut down tight, you will have a large 'f' number and a much larger area in front and behind your subject that is in focus.What do you mean about that?the biggest fault lies with the backgrounds. So work on seeing the backgrounds
People spend lots of money for lenses with very low 'f' numbers so that they can intentionally blur out the background of their portraits while having sharp subjects. Your third photo is a good example of blurred background, though it is not quite blurred enough to avoid being a distraction, and your subject (up close) is nice, but not really compelling. A lens with, say, f/1.4 would have blurred out the background significantly more, but at a significant financial cost to purchase.
BTW, these aperture settings are called f-stops, and there is a scale which reflects a doubling of light needed for the same shot. Google 'exposure triangle' for a detailed discussion. It's a little techy, but crucial to our art.
I'll let canon shooters speak to the 1300D, but I can assure you that the nikon D3400 plus 'kit' lens is technically a much better setup than the D40 due to major advances in technology (focusing systems, image quality in low light, vibration reduction, etc).Oh.. Now I understand much better, but I also have some question... My camera is not too old? and is it good for beginners? Cause, I don't know a lot about cameras...
Maybe one of these cameras are better? Can you recommend?
Veidrodinis fotoaparatas NIKON D3400 + 18-55mm VR
Veidrodinis fotoaparatas Canon EOS 1300D Kit + EF-S 18-55 IS
That all being said, the D40 can still produce some lovely images. Look at the eyes in your cat photo- great focus and clarity. A great photographer with an 'ok' camera will get much better images than an 'ok' photographer with a great camera.
Obviously, we would love to be great photographers with great gear at some point!
Your camera is fine. Please do not think you need the latest equipment to make good images.My camera is not too old? and is it good for beginners?
But why some people says that D40 is fine, some says I need to change my camera?Your camera is fine. Please do not think you need the latest equipment to make good images.My camera is not too old? and is it good for beginners?
I need to ask you, can you rate these photos from 1 to 10?
Based on the above I would suggest you use the search on here and search exposure triangle or look through the beginners section. There are some great suggestions for books on photography.What is that?doesn't dip below f/3.5
We have a classification of people we call; "Gear Whore". Don't listen to them.But why some people says that D40 is fine, some says I need to change my camera?
