NJMAN
- Joined
- Aug 1, 2006
- Messages
- 2,104
- Reaction score
- 2
- Can others edit my Photos
- Photos NOT OK to edit
Thanks! I used my 30D and switched between 2 lenses. The 50mm f/1.8 was used for closeup shots and the 18-55mm was used for wider angle and group shots from various ranges. Most of the shots in the church were done without flash, especially during the ceremony, but I got a few shots with flash there also. I had my 580EX speedlite, which was used at the reception and dance about half the time, and I also had a homemade diffuser/bounce card on the top made out of white foam and secured it with a big black rubber band (works just as well as a fong lightsphere or a stofen in my opinion).
If you like these, you should check out the second set.
