First Successful HDR
Discussion in 'Beyond the Basics' started by keith204, Aug 30, 2008.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    Alright, after quite a bit of playing, I finally ended up with something I really like. Heck, I even like it enough that I put a black border around it to help balance the colors for online use. This came from one RAW file, exposed 3 ways and output to separate RAW files, then into Photomatix.
    Canon 40D
    ISO 400
    Sigma 10-20mm @ 10mm
    f/11 1/250sec
    Here are the three 'exposures'
    [​IMG]
    [​IMG]
    [​IMG]
    What do you think?
    [​IMG]
  2. Moglex
    Moglex TPF Noob!
    Jun 13, 2008
    578
    Whitstable
    Could you expand on that a little, please?
  3. Bryant
    Bryant TPF Noob!
    Jun 25, 2008
    225
    Connecticut, United States
    I think he means that he took only one shot in raw. Then in Camera Raw, he made it two stops under exposure, and then exported it into a new file. Then made it to stops over exposure and did the same. He then got 3 shots and used photomatix.
  4. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    Yep
  5. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    You realize of course you didn't gain anything at all (except the experience of doing it) by taking it through a process like that right?
    You can achieve the exact same results in several other much easier, ways without making separate files.
    Since all the information you used in the assembly came out of one RAW file simple logic should tell you that indeed all of the information is contained in the one RAW file. If it's all there to begin with splitting it apart and reassembling it is just the hard way and the long way of selectively adjusting levels. There are better tools for doing that than having to go through the extreme hassle of loading and saving it three times and then trying to combine and tone-map the three into one. ;)
  6. Moglex
    Moglex TPF Noob!
    Jun 13, 2008
    578
    Whitstable
    I didn't want to rain on your parade but he's correct about not gaining any extra information if not necessarily about there being an easier way for that particular result.
    You can see get an idea of what can be achieved from the work you've done so the next thing to do is to take a set of 'bracketed' shots and use those as input to Photomatix (or whatever tool you use).
    If you have easy access to the subject of the shot you showed above it would be instructive to try and get three shots with the same lighting conditions (as above) and compare the results.
    The difference may not be that great with that particular subject but would be very noticable with more 'difficult' (i.e. contrasty) ones.
    Whatever, I do actually rather like your shot.
  7. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yea, these guys are right about not gaining any extra information by using photomatix, However.....i disagree about it being a 'long' way to achive this effect... in fact it is probably one of the shortest ways to increase the visable range of a RAW file.
    I prefer to take longer creating more range in my images using curves adjustment layers, sometimes adding screen layers etc to increase range... using photomatix is alot quicker but gives less control. The last time i used it (last week) i created the 3 seperate exposures and had finished loading them to Photomatix within about 5 mins!
    As for the result, i kinda like it although the saturation is a little high for me.
  8. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    I agree with the satuation, nice pic to choose for this effect though.
  9. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    I think a little burning (no pun intended) and slight desat. on the foreground while keeping the background as-is would make this photo top notch.
  10. rubbertree
    rubbertree TPF Noob!
    Sep 7, 2007
    727
    Canada
    just a quick hijack...
    When doing HDR with 3 bracketed exposures, should you do it in jpeg rather than RAW? Or would 3 bracketed RAWs still give you all the information?
  11. Moglex
    Moglex TPF Noob!
    Jun 13, 2008
    578
    Whitstable
    Always use RAW for the greatest flexibility.
    You will never lose information by shooting RAW.
    You will always lose information by compressing to JPG.
  12. photo28
    photo28 TPF Noob!
    Aug 7, 2008
    794
    New York
    :thumbup:
