First time developing confused :(
Discussion in 'The Darkroom' started by zamanakhan, Sep 2, 2010.
  1. zamanakhan
    zamanakhan TPF Noob!
    Sep 2, 2010
    473
    29
    i really wanted to get into my own developing of film, i've been shooting digital for a while and figured hey i have the lenses lets pick up a cheap slr locally so i picked up a n90s for $40 with the special back. I also picked up a holga tim which actually cost me more. I have ordered a stainless steel tank and a plastic reel and the kodak developer fixer and the water softner all from kodak along with a change bag. I've already run into problems, the plastic reel doesnt fit in the stainless steel tank :( but iam ordering a plastic tank right now. so my questions are as follows:
    1. can i develop color film in b&w chemistry? its fine if the film develops b&w i only ask because b&w film is much more expensive than color and i wanted to primary shoot b&w, plus half the time i might be shooting with a holga so quality isnt a HUGE issue at all.
    2. which chemicals can i reuse? and how often can i reuse them? i keep hearing u can use developer this often and then discard it or fixer is good for 12 batches and discard it... everywhere i look there are different opinions, what amount is the correct amount?
    3. the solutions i have purchased are powder based, is it possible to simply dilute chemicals everytime i develop, instead of developing all at once? e.g take a tablespoon of powder and 500ml of water and dilute that for one developing go, or do i have to dilute all the solution in a 4g bottle and then pour in the correct amount in tank?
  2. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,039
    508
    L.A.
    You can develop color film with B&W chemistry but the results are usually pretty
    bad. But, since you can buy very good B&W film for about $2 a roll for 35mm and
    about $3.00 for 120 (Holga) film from Freestyle, there's really no need to mess with
    that solution.
    It varies. Always follow the manufacturers recommendations for reuse of
    chemicals. Some developers can only be used once, some can be reused.
    Just read the info that comes with the particular chemical and follow it. Or,
    go the the manufacturer's web site and get the info there. Fixers can
    usually be reused and they can be tested before use to see if they are still
    good.
    With powdered chemistry you have to mix the entire package. This is
    because the chemistry actually contains a number of different chemicals
    and they will not be evenly distributed throughout the material in the
    package. This is one of the big advantages of using liquid chemicals
    because they can be mixed a little at a time as needed.
    As you gain more experience and confidence you can also mix up your
    own chemistry from scratch by buying what you need from chemical
    suppliers. That way you you can mix up exactly the amount you want
    and it will be fresher and more pure than commercial products and cost
    less too. Many popular photochemical formulas are easy to find on the
    web and in books.
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    go to Ilford's website and take a look at their pdf for making negatives. very easy and simple.
  4. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    1) black and white films are not more expensive then color, actually the reverse is true. It's just harder to find "cheap" b/w film. If you want cheap b/w film check out Freestyle Interactive - Homepage. Neopan SS is a good choice, it's less then $3 per 36 frame roll.
    2) You should buy liquid developer if you want to mix it up "as you go," hc110 and rodinal are the most commonly used. The concentrate lasts almost forever, and you just mix up what you need when you need it.
    3) You can reuse fix and stop, but developer should be mixed up 1-shot (when using liquid concentrate).
  5. zamanakhan
    Sep 2, 2010
    473
    29
    i cant find any film on that website...
  6. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
  7. zamanakhan
    Sep 2, 2010
    473
    29
    thnx!!! will order from here next time to see how everything is!!
  8. classcams
    classcams TPF Noob!
    Nov 19, 2010
    16
    york
    The problem is the film has to be washed in DIFFERENT water after every operation.
  9. ann
    May 14, 2007
    4,263
    189
    no, the film is washed after it has been developed, put into stop bath and then fixed, then wash. It can be running water for at least 5 minutes or use the Ilford method of fill and dump after agitation. First wash is 5 agitation, the 10 then 20, saves on water.
  10. djacobox372
    May 4, 2008
    2,925
    129
    Seattle, WA
    Here's a tip on washing: I use tap water for all my washing, except the last wash. The last wash is done in distilled water with a few mm of photo-flo. My negs come out very clean using this method.
