First time shotting with entry level SLR
Discussion in 'Photography Beginners' Forum' started by rodneylynn1977, Feb 14, 2009.
  1. rodneylynn1977
    rodneylynn1977 TPF Noob!
    Feb 14, 2009
    4
    Everett, WA
    This is my first time shooting with a SLR, I am currently learning with a Canon Rebel XS... I was 3 rows from the top, using a 50 x 300 lense. I want to find a photography class soon.
    Any ideas on a clearer picture? How do I speed the shutter up?
    [​IMG]
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    What shooting mode were you using?
  3. rodneylynn1977
    Feb 14, 2009
    4
    Everett, WA
    I was using sport... I was 28 rows off the floor, and I couldn't afford the expensive lense...
  4. Pure
    Pure TPF Noob!
    Oct 22, 2008
    418
    Since you can't use a flash....
    Boost your ISO, and use shutter priority mode.
  5. rodneylynn1977
    Feb 14, 2009
    4
    Everett, WA
    I am not sure I can do the shutter part lol... I am way knew to this...
  6. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    There is nothing wrong with the way you were shooting... A mono pod or tripod will help as I think that most of the issue is camera shake from a long lens.
    The Sport mode, I believe, automatically shifts the Auto Focus mode to AI Servo AF, which will lock onto your subject and keep focus sharp while it is moving, and compromises on the shutter side for exposure. (shutter priority)..
    To increase your shutter speed and still use the Sport mode, you need to increase your ISO... 800 will give you a little increase in that shutter and from the looks of the frozen ball and most of the players it should yield respectable results.. You could possibly push the ISO further but would likely introduce some noise.......
    Your lens is probably holding you back from very much more speed...
  7. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    I dont understand when people say this, i think you should use shutter priority when you want to control how much blur you want to add/remove to a photo.
    In this situation you probably use Aperture priority (so the shutter is always the fastest, but has proper exposure, your lens is limiting your exposure, not the shutter speed... Depth of field shouldnt be an issue, so I would true bumping up the ISO, putting in aperture priority and opening the aperture as big as it will go (lower F/number)
    Edit:
    EXIF data shows:
    Rebel XS
    F/4.5
    1/125
    ISO 400
    Focal Length: 100mm
    Just to get rid of the camera shake, you should use at least 1/100, and since its sports and you want to freeze action, you need it even faster, 1/125 isnt too bad....
    I think ISO 400 is almost the limit with the XS before it starts to get pretty grainy, you should try ISO-800 which will be a 1/500 shutter speed with f/4.5 (if its wide open) aperture, which might be good enough in your situation... It might be grainy tho... Try a monopod!
  8. rodneylynn1977
    Feb 14, 2009
    4
    Everett, WA
    Maybe next year I can afford a nicer lense... I really would like to find an entry level photography class.
