First Wildlife pic - Blue Heron
Discussion in 'Nature & Wildlife' started by F-StopBlues, Feb 23, 2010.
  1. F-StopBlues
    F-StopBlues TPF Noob!
    Feb 23, 2010
    6
    Maryland
    First attempt at any sort of wildlife photo. Tried to get one of it flying but the light was too low to avoid blur.
    [​IMG]
  2. EricD
    EricD No longer a newbie, moving up!
    Feb 25, 2008
    1,661
    197
    Geneva, Florida
    Nice job for your first attempt!! I like how you managed to capture the entire shadow as well. You might want to lighten up the bird a little, he seems a tad dark. For me Dark birds in low light I usually underexpose a bit to lighten up the bird.
    Nice job all around...keep them coming!! :thumbup:
  3. HikinMike
    HikinMike No longer a newbie, moving up!
    Nov 6, 2009
    1,438
    147
    Atwater, CA
    Congratulations! Took me a long time to finally capture one of those.
  4. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I agree that this is an excellent first attempt. From the positive side, the composition is wonderful and you got the bird's face in profile -- also a definite plus. Try lightening it and see how it looks, but shooting to the left side of the histogram may have made enough lightening impossible. Was this handheld? If so, and you are limited with a slower lens, consider using a tripod next time to be able to drop your shutter speed (although you would have missed those lovely ripples on the water) . Most importantly, keep shooting!
  5. F-StopBlues
    Feb 23, 2010
    6
    Maryland
    Thanks for the input. Yes it was a handheld shot because I didn't want to miss it trying to get my tripod out(and since I'm still new to it I don't have a fast enough lens, it was probably set at the max of 5.6 at 200mm). How do you pull the shot info out of the file? I have a RAW copy of it so I could certainly try to lighten it more if I had a good program for that (the stock Nikon viewNX I haven't figured out yet). Any recommendations?
  6. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    200mm f/5.6 1/80sec ISO 400 (Jeffrey's Exif viewer)
    I'm sorry, but I don't know anything about the NIKON software. I use CS4 and/or LR2. I'm at work, so I don't have it available to me at the moment, or I'd try it for you. Maybe someone else can jump in and give it a try. If you are able to lighten it, I think it could be an outstanding image.
    I'm actually quite impressed that you were able to handhold it that well at 1/80 sec.
  7. F-StopBlues
    Feb 23, 2010
    6
    Maryland
    Wow, thank you.. that's amazing how much information is embedded. I really do need to upgrade to cs4, I have cs2 now and it doesn't handle raw images. (I did have something to rest my elbows on, that's the only reason 1/80th worked out, I'm not that steady :thumbsup:)
    I'll work on it and see what I can get. Thanks again.
  8. F-StopBlues
    Feb 23, 2010
    6
    Maryland
    Ok, I lightened the picture but you lose all the detail in the water so I darkened that but put a layer mask on the Heron. I feel like it looks too unrealistic though so I'll keep playing.
    [​IMG]First attempt at that.
  9. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    Much better!
  10. Shocknawe
    Shocknawe TPF Noob!
    Jan 31, 2010
    180
    northern,WI
  11. Kethaneni
    Kethaneni TPF Noob!
    Sep 9, 2008
    226
    South riding,VA
    Good job on the first attempt. The picture would have been even better if there was a little bit more water(dead space) in the top half of the frame. But, it's just me.
  12. USM IS
    USM IS TPF Noob!
    Jan 4, 2010
    205
    Iowa
    I actually like it a little darker.....Mike
