fisheye or ultrawide?
Discussion in 'Photography Equipment & Products' started by anel, May 15, 2010.
  1. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    i made up my mind a while a go to save up for the sigma 10-20, but i've been thinking about fisheye lenses lately.. how much work is needed to fix the distortion, and is it worth it, can i get a fisheye lens cheaper than a ultra-wide lens? i'm shooting with a 30D canon.
  2. cfusionpm
    cfusionpm TPF Noob!
    Jun 21, 2009
    852
    6
    San Diego, CA
    Keep in mind fisheye lenses are also fixed focal length (they don't zoom), and if you don't want the fisheye distortion, a super wide angle is the only way to go.
    This was taken at 10mm on my 50D:
    [​IMG]
  3. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    isn't there any way to fix the fisheye distortion in post?
  4. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    yeah, you can fix the fisheye distortion in ps.
  5. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    why would you fix something that the lens is supposed to do? I mean the desired effect and reason for a fisheye lens is to create a really wide and distorted image, no? If you just want a really wide angle, look at the sigma 10-20 or similar lens. Generally I think you are probably going to pay more for the fish eye. IMO the fish eye is of really limited use and has a small niche of use. It would be probably the last lens on my wish list.
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    By and large, you get the fisheye for the fisheye effect. If you just need wide, get the Sigma. It's a solid lens. It's the only non-Nikon lens I own and I use it quite a bit.
  7. Dallmeyer
    Dallmeyer TPF Noob!
    Mar 23, 2010
    351
    I was going to ask then i thought ...nah
  8. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    Can I see an example? PS may be able to do it but, somehow, I have a hell of a time imagining usable results.
    And, as mentioned by both Johnboy and manaheim, what would be the point?
    Now, as far as your choice, the fisheye is an ultra specific-use lens which is used by most people as a special effect which, imho, is usually a fail.
    Even superwide I found to not use much at all. I had a 20mm (12.5mm on a crop) and I sold it within about a year because it was just too darn wide. A 24mm was as wide as I needed. The 20 looked too much like a special effect to me and special effects start looking old real fast.
  9. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    Tokina makes a fisheye zoom.
  10. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    well i thought that with a fisheye i would kind of have both, a fisheye lens and an ultra-wide if it can be fixed in ps. but seeing as how it can't be or doesn't come out just right, what are my ultra-wide options? anything else than the sigma 10-20? i guess it's pretty cheap and sharp.. anything cheaper? :D
  11. manaheim
    Sep 2, 2005
    14,394
    3,262
    It can be but it basically scrunches the image down... imagine pulling all the corners of your image in.
    And for ultrawides, IIRC, the Sigma 10-20 is the cheapest. They have older copies you could pickup which might run a little less. I think the newer one is a bit improved.
  12. shaunvdl
    shaunvdl TPF Noob!
    May 26, 2010
    Oxford
    does anyone know the best fisheye attachment for a Cannon D500? I know that the quality is not as good as when you buy the lense but I am only getting it for fun. thanks
blury edges fisheye fix
fisheye or ultra wide
fisheye vs ultra wide
fisheye vs ultra-wide
fisheye vs wide angle
how to fix fisheye blurry
photography forum
reasons to get a fusheye
wide angle vs fisheye
