Fist try at Photoshop
Discussion in 'Photography Beginners' Forum' started by eric-holmes, Oct 6, 2009.
  1. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    49
    Arkansas
    I have been messing with PhotoShop for about a day and here is my first try. I thought it came out ok. Nothing great, just ok. I have a problem though. How can I make my quick selection less jagged? For example, my right ear.
    [​IMG]
  2. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    hah i haven't figured out how make selections better around stuff either... i even tried the whole refine edge thing but i can never do it right unless it's a super hard edge...
  3. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
    There has to be some way. Maybe shooting against a green screen would work better.
  4. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    I find using a Wacom Tablet just better for that kind of thing.
    as well using a layer mask will improve the look ar well.
    As well you should mirror the image so the text is correct and does not look like it was shot in a mirror
  5. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
    Yeah, I should mirror the image lol
  6. Felix0890
    Felix0890 TPF Noob!
    Oct 2, 2009
    472
    Miami , FL
    Next time, use feathering to soften the edges. Whenever you select the part you're gonna keep, go to Select > Modify > Feather. Enter pixels that are appropriate for the size of the picture; the bigger the picture's resolution, the bigger the number you enter in there. After you do that, just copy/paste or whatever and the edges will look softer.
    About the tablet, I have a tablet PC and actually find it easier to select using the magnetic tool and my mouse. Tablets aren't for everyone.
  7. RussJasper
    RussJasper TPF Noob!
    Sep 3, 2009
    59
    London, Ontario
    Don't do quick selection, thats your problem. you need to use the lasso tool if anything and zoom in a lot. it takes a lot of time but with something that basic it shouldn't be hard at all and will look way better in the end. or even quick select but make it more than you need then go in close and use the eraser to bring it closer.
  8. fiveoboy01
    fiveoboy01 TPF Noob!
    Dec 28, 2008
    684
    Waunakee, WI
    You could also use layers to accomplish what you're trying to do.
  9. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    The quick selection tool works great but you have to zoom in a refine the selection.
    As mentioned feathering helps once you have the edge selection done and masking is even better.
    I have to second using a pen tablet. I use my pen tablet for nearly everything except typing including surfing the web.
    If you don't have one Wacom just updated their Bamboo line but I can't recommend anything less than a Wacom Intuos 4 Medium.
    If you can afford it look at the Cintiq tablets....Sweet.
  10. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
    Here is try number 2. I feathered the edges slightly and I fixed the Nikon orientation on the camera.
    [​IMG]
  11. Felix0890
    Felix0890 TPF Noob!
    Oct 2, 2009
    472
    Miami , FL
    Looks MUCH better with the feathering. :)
    However, you made the feathering a bit too noticeable. The edges on the outside of your hand and ear are a bit too blurry. You can either redo the selection with a smaller feather setting or, if you used layers, use a layer mask to remove a bit of the blurring from the hand while keeping the rest of the selection as is.
  12. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
    I feathered the edges about "3". I assume that means pixels. Anything more and it started to look like I did it on PicNic. Which is a no-no.
