Flash at end of exposure
Discussion in 'Beyond the Basics' started by Ricky21, Jul 6, 2010.
  1. Ricky21
    Ricky21 TPF Noob!
    Mar 25, 2010
    73
    San Antonio, Texas
    Does anyone know if you can set the on camera flash to fire at the end of the exposure on the Canon Rebel XS?
  2. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    Should be able to. It's called second-curtain sync. Look for it in your menu options.
  3. Shaneuk
    Shaneuk TPF Noob!
    Apr 16, 2010
    88
    Derby UK
    You could do the above or you can press the test button, if you flash gun has one.
  4. Ricky21
    Ricky21 TPF Noob!
    Mar 25, 2010
    73
    San Antonio, Texas
    Ok, that is what I thought it was when i was playing around in the menu options. Thank you.
  5. smokinphoto
    smokinphoto TPF Noob!
    Jul 8, 2010
    98
    San Francisco,CA
    Yea like people have said above, try second-curtain sync
    Depending on the speed and direction of movement and the intensity of the lights, it doesn’t always work this way but one of the great things about digital is that you can review your results and try something different if you didn’t get what you were expecting.
    It bears noting that you can’t precisely control exactly when the flash fires when using second curtain synch. So it’s possible in our example scenario that the subject could be out of the frame before the flash goes off. Second curtain synch requires some practice, a bit of finesse and sometimes luck to use well.
delayed flash end of exposure
flash at end of exposure
