Flash Batteries
Donde
TPF Supporters
Supporting Member
Cali, Colombia
For some time I have used Powerex 2700 rechargeable batteries in my Canon flash with good results but I wonder if there are other batteries with even more capacity. I tried a set of Eneloops and while they worked well they didn't seem to have more capacity and they quit recharging after a year's use.
2700 mAh is about as good as it gets for AA batteries.
I too use the Powerex AA's instead of Eneloops.
I once made an extensive test with more than 8.000 flash ignitions to check which batteries work best for me. I do have rather long periods when I don´t use speedlights and then I don´t want to discharge/charge them before a shooting. So it is important for me that batteries don´t loose power when they are not used. One of the batteries in the test (the most expensive one!!!) lost more than 50% capacity in 30 days!!!
After that test I bought all eneloops because I felt they were the best value for money, see the result for yourself:
A short explanation:
  1. I refreshed every single battery before I first used it (discharge/charge) then I checked the number of possible flash ignitions right after that first charge.
  2. After they cooled down, I recharged them, put them into the cupboard and waited 15 days before I did my next test with the same batteries.
  3. After they cooled down again, I again recharged them and waited 30 days this time. You can see the result below.
While some batteries have more power right after charging, they lose it pretty quick.
I don´t know if it helps.
Here´ a table with some details - I have more in case you are interested:
BatteryPrice in EURcapacity ratingMeasured capacity after first charge
Ansmann maxE+11,1025002494,5
Ansmann Professional14,2628502829,25
Sanyo Eneloop9,6220001963,5
Sanyo Eneloop XX14,1025002618,75
Duracell Stay Charged13,2320001949,25
Duracell Supreme9,6424502463
Varta Power Akku9,5327002714
Varta Professional12,3227002692,75
Varta Stay Charged9,0023002361,75
[TBODY] [/TBODY]
