Flash Cables.
Discussion in 'Photography Beginners' Forum' started by Kiske, May 20, 2008.
  1. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    So,
    My hotshoe doesn't work...
    Are there any adaptors that I can attach to a flashgun directly from the studio flash plug/thing?
    And yes, my technical terminology is amazing.
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    What kind of camera (Make, model). If it has a Flash-sync outlet (a small round port about 2mm in dia) then yes, if not, you're probably out of luck.
  3. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    It's a 1d, it does have the flash output.
    I just cant seem to find a suitable cable on the net.
  4. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Define suitable...
  5. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    I basically need to connect the flashgun to the cable socket, rather than the hotshoe, and so that the flahs works as it would do normally.
  6. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    What model flash is it?
  7. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    580EX II speedlite.
    Thanks for this btw! Saving my ass!
  8. Village Idiot
    Mar 20, 2008
    7,274
    406
    Get a standard PC cable. Male to male I think? Some one should confirm this first.
  9. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    That should have an outlet so that you can use a cable from your body to the flash, or, failing that, get one of these nifty little numbers, plug it into the camera, and you have a movable hot-shoe: http://dpanswers.com/images/pc2hotshoe_web.png
  10. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    Thats exactly what I was looking for tirediron, thanks!
  11. Black Magic Studio
    Black Magic Studio TPF Noob!
    Mar 24, 2007
    12
    St. Louis, Missouri
    If you find an adapter, the flash probably still won't work normally. The PC terminal is very generic, and just tells the flash when to fire. You will likely lose all of the ETTL features of the 580EX, which knows things like how strong (bright) to fire based on the distance and aperture, how wide to cast the light based on the zoom, etc.
    What you are looking for is a PC to Hot Shoe adapter. B&H part number GBPCHSA is one. Kaiser part number 201301 is another.
  12. Kiske
    Kiske TPF Noob!
    Mar 3, 2008
    6
    thankyou
