Flash cord problems, Help
Discussion in 'Photography Equipment & Products' started by 250Gimp, Mar 21, 2007.
  1. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    I just bought a used off camera flash set up. It consists of a Canon Connection Cord 60, Hot Shoe Adapter, and TTL Off Camera Shoe Adapter 2.
    When I hook it up to my Digital Rebel Xt and 430EX flash, nothing happens. Am I doing something wrong? Do I need to set something in the camera or flash? Because I bought it used it has no manual and I can't find any info on it in my camera or flash manual.
    If anyone can help I would greatly apreciate it.
    Cheers
  2. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Anyone?? I could use some quick help on this.
    Thanks
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Can you take a photo off all the parts, to show us? I wish I knew more about this, but I don't.
    I don't know if there is an easy way to test the cords, that would be my main concern if things aren't firing.
  4. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    the cord is basically a bunch of wires with special adapters for the camera and the flash.....to test it......you'll need an ohm-meter......then you basically check the resistance of each contact...make sure that it goes from one end to the other with a very small resistance.......
  5. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    What are the chances these aren't compatible with my set up?
  6. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Well....after much searching I think I have found the problem!
    Even though I checked the Canon Canada website and spoke to a "knowledgeable" camera salesman before purchasing, this set up is not compatible with Canon digital SLR cameras because they require E-ttl metering, and this cord only provides TTL metering.
    It is unfortunate that the Canon Canada website does not mention this, but the american website does! I didn't think to check two Canon websites!
    Anyway, just thought I would let anyone know that is following this thread.
    Cheers
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Sorry about that, I wish I would have know that before as well.
