Flash for Mamiya m645
Discussion in 'Beyond the Basics' started by Commonman, Feb 3, 2007.
  1. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    I've got an old Mamiya m645. It has 2 terminals on the side. One is labeled X and the other is labeled FP. What do these designations mean?
    Also, if I want to use a Vivitar Auto Thyristor 550 FD that has a hot shoe to PC converter (because there is no hot shoe on the Mamiya since it has a view finder that precludes the hot shoe), which terminal should I use?
    Also, which f stop and shutter speed should I use. I noticed there is a 60x setting and just a red dot with a circle around it on the shutter speed controller. What shutter speed should I use? The Vivitar says to use f stop 4 but this still leaves the question of what speed setting. I know this has to do with the distance of the subject.
    I guess I'm hoping somebody out there is familiar with the old Mamiya m645 and has used the flash terminals. I know, I know - why don't I find a user manual.
  2. Azuth
    Azuth TPF Noob!
    Dec 25, 2005
    262
    Sydney 'strailya
    From a very quick web search "The FP contact is closed via the opening curtain latch, which is tripped by a linkage on the mirror cage approximately 7- to 15-milliseconds before the curtain clears the opening side of the film plane. The X contact is closed via a cam and insulated stud on the bottom of the opening curtain drum. The contact is closed only as soon as the opening curtain complets its travel across the film plane. "
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    FP stands for focal plane and is the right synch for old fashioned flash bulbs. X is the right synch for electronic flash. The synch speed should be 1/60 or 1/30 depending on the model. If your 1/60 is detailed in red on shutter speed dial then that is maximum synch speed.
  4. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
  5. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    Thank you all very much. Yes the 60x is in red so that surely is the maximum shutter speed to use.:blushing:
    Regarding using a bracket, yes that's what I want to get! It's too much of a hassel to hold the flash unit in one hand and the camera in the other - especially since this is a bulky and heavy camera. However, sometimes it might be good to hold the flash to get a different flash effect - but the flash has an directional position thing - different angles - for bounce back stuff - so the bracket is definitely:D a great idea.
  6. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    This is my setup it is slightly unweildy but it has served me well for a good many years.
    [​IMG]
  7. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    JIP, looks like a cool set-up. I like the flash with the handle.
  8. Mike_E
    Jan 26, 2007
    5,327
    266
    Definitely look into getting a Metz for that rig!
    The 60 is a great flash for anything up to low flying aircraft. (I'm not kidding)
    The 45 CL 4 is 3/4 as powerful and still has a guide number of 45 meters.
best flash for mamiya 645j
flash mamiya m645
flitser mamiya 645
mamiya 645 flash
mamiya m645 flash
mamiya m645 flashes
using flash on mamiya 645 1000s
