Flash or Strobe lighting kits?
Discussion in 'Photography Equipment & Products' started by Stephi, Jan 27, 2009.
  1. Stephi
    Stephi TPF Noob!
    Dec 29, 2008
    57
    Devon, United Kingdom
    I have heard that flash lighting kits are better for all kinds of photography work, but especially portraiture, but I have seen quite a few people on here use strobe lighting kits.
    Which do people think is the best for taking portraits of people in studio and home settings, flash kits or strobe kits?
    Many thanks
    Steph
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Typically, the terms flash and strobe are synonymous.
    By flash do you mean 'hot shoe' units that would typically be used on top of the camera?
    And by strobe do you mean studio lights that are plugged in?
  3. Stephi
    Stephi TPF Noob!
    Dec 29, 2008
    57
    I mean as in studio lights - I think I may have got confussed here! lol I probably meant continuous lighting actually. Its just whilst looking at some lighting kits they seem to be broken down into two sections - flash kits and strobe kits - so I just assumed flash kits were when the trigger was on the hot shoe and set off all the other lights and stobe were continuous lights?
    I'm really not sure now! sorry
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Flash and strobe are basically the same thing.
    Continuous lighting is often referred to by the type of bulbs...incandescent, florescent, halogen etc. They might also be called 'hot lights' etc.
    It sounds like you had some of the terms mixed up, but you are asking the right question. When you are considering lights, the first decisions is probably whether you want to get continuous lights or flash/strobe.
    Continuous lights have the advantage that what you see is what you get, so you can set everything up to look just right and then shoot it. For the most part,
    they are also less expensive than flash/strobe lights.
    The downside to continuous lighting is that you need a lot of it in order to get exposures with fast shutter speeds, which you need if you are shooting hand held or shooting moving subjects like people. If you are shooting still objects and can use a tripod, then continuous lighting is fine, but for shooting people, flash/strobes are highly recommended. Also, continuous lighting can get pretty warm for your subjects.
    Flash/strobe lighting can be a bit of a mystery because it's typically not 'what you see is what you get'. However, studio strobes do usually have modeling lights which help to give you an idea of what you are doing.
    The big advantage of flash lighting is that it's a very quick burst of light which freezes most movement, which usually makes for sharp photos.
    So if you are going to go with flash/strobe lighting...there are a few options. Option one is studio strobe lights...typically 'mono-lights'. These lights will usually go on light stands and have to be plugged into a power source. There are some cheap, underpowered kits floating around but a good kit will have plenty of power.
    Option two is to use 'hot shoe' flash units. These are much smaller and run off of batteries (usually AA), which makes them a lot more portable than studio lights. Check out THIS SITE for plenty of info on using these types of lights.
    There are pros and cons to each choice...so this is something you need to decide for yourself.
  5. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    :thumbup:
    What can I say Mike. .. you should be a teacher. :)
  6. Stephi
    Stephi TPF Noob!
    Dec 29, 2008
    57
    Wow thank you thats exactly what I needed to know, thank you very much :) and thank you for not thinking me stupid for getting mixed up :D
