Flash question again
Discussion in 'Photography Beginners' Forum' started by Robin Usagani, Aug 11, 2010.
  1. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    I have 500D (t1i) and 550 EX. Is it true I cant trigger the 550 EX off the camera with my pop up flash? If I can, how do you do it? I have set it as slave but I cant seem to trigger it.
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I do not think it can be done without using a optical slave trigger device. But the pre-flash from the build-in flash may cause issue.
    If you want to go low cost, those cheap radio trigger works pretty well especially when use it outdoor during the day when optical trigger may have issue.
  3. ajkramer87
    ajkramer87 TPF Noob!
    Jan 7, 2010
    443
    York PA
    Does the T1i have commander mode?
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    No, you can't trigger an off-camera 550EX with just your camera.
    The only camera in Canon's line up that can do that, is the 7D.
    You will need another master unit (or another slave unit). If you add another 550 or 580, then you could use one (on-camera) to trigger & control the other one. You could add the ST-E2 (non-flashing master unit) or you could get a 420/430 and use that as a slave to your 550.
    Any of these options will give you full E-TTL functionality with the remote flash, which is cool...but the problem is that it uses light pulses for communication which means that you need line of sight when outdoors and bright sunlight hinders communication.
    Another option would be to use a radio trigger set. For as cheap as $40, you could get a trigger set that will allow you to fire your flash off-camera. You would not have E-TTL metering etc....so you would have to set the flash power/exposure manually, but it's not that hard to do.
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    No, that's a Nikon thing.
  6. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Big Mike, can you recommend me a link on amazon or ebay for a cheap but works like a charm solution?
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    HERE is one that a lot of people use.
  8. Craiguk
    Craiguk TPF Noob!
    Aug 6, 2010
    8
    Peterborough UK
    No you cant trigger it off camera without a flash trigger which are easily obtained from Ebay at very little cost.
  9. MohaimenK
    MohaimenK TPF Noob!
    Nov 13, 2008
    2,583
    11
    In between her...
    Here's also a good one. I'm using this for my 580EX when I use it w/ the umbrella
    [ame="http://www.amazon.com/CowboyStudio-NPT-04-Wireless-Receiver-cowboystudio/dp/B002W3IXZW/ref=sr_1_1?ie=UTF8&s=electronics&qid=1281538512&sr=8-1"]Amazon.com: CowboyStudio NPT-04 4 Channel Wireless Hot Shoe Flash Trigger…[/ame]
    MIKE (or anyone) Do you guys know if the recharg time is longer w/ a trigger vs using it through the camera? It seems to me when I have it mounted to the camera Its super fast but off camera, the flash takes a few sec to recharg?
  10. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The recycling time of the flash is a result of how it's designed, the type & power level of the batteries and how much power it used for it's previous flash. The last point being the key here.
    When you fire a 580EX at full power, it can take a couple seconds to recycle...but when you fire it at 1/64 (or something like that) it takes almost no time to recycle.
    When it's on-camera, you are likely using E-TTL metering, and unless your subject is rather far away or you're using small apertures, then the flash is probably not working very hard....so you get quick recycle times.
    So the question is, what power levels are you using when you fire it off-camera? (If you leave it in E-TTL mode, it will fire at full power.)
    Flash power is just one part of the exposure equation, so you can require less power from the flash if you use a larger aperture, use a higher ISO or move the flash closer to the subject. So by requiring less power, you get faster recycle times and longer lasting batteries.
  11. MohaimenK
    MohaimenK TPF Noob!
    Nov 13, 2008
    2,583
    11
    In between her...
    I normally set it to 1/2 or 1/4 power as everything is manual mode. Unless I dish out them oney and get the canon trigger which will alow me to use ETTL. But yeah, even at 1/4 power it seems it takes a few sec. Around 10 sec? I also have a new battery which I used to shoot maybe 50 images as test?
  12. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Mike, i will borrow my friends 580EX. So it is possible i can set off the 580 ex with my 550 without setting off my 550 of the camera? HMM how come the thank you icon is missing??
