Flash recomendation
Discussion in 'Photography Beginners' Forum' started by Phazan, Apr 24, 2008.
  1. Phazan
    Phazan TPF Noob!
    Dec 26, 2006
    737
    Bay Area, California
    Hi, I decided to buy an off-camera flash unit with my tax returns. I've done my homework, and researched flash units, but I still don't really know what I need. :meh:
    I was thinking of getting a caple, and the cheapest Canon flash unit, but is there THE flash unit that most people have? (example, like the 50mm 1.8...it's so cheap, and nice everyone has one) I just want a good off-camera flash to experiment with. My budget is $150, and it has to work with my 40D (obviously). I don't really care about the automatic metering and stuff. I just need something to get the job done.
    thanks for any help!
  2. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    I picked up a Sunpak 2800 from best buy just for something better than my onboard flash that would allow me to bounce as well as adjust. Its got a slow recycle time but it is adequate for what I need as of now. It was 62.99 I believe. This is only until I get the 430 or 580 but my budget at the time was towards something else.
    If you have 150 to spend check out the sunpak 383. Its a good off camera flash.
  3. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    If your going to be using it off camera dont bother with any ttl flashes from canon. Just get something like a sunpak 383 or a vivitar 285 and trigger it with some gadget infinity cactus v2 triggers. And when your there make sure to by at least 2 receivers because you will eventually wanna add another flash to your system
  4. Village Idiot
    Mar 20, 2008
    7,274
    406
    I second the Sunpak 383. You can get them for $80 from most online retailers.
    Also, if you're serious about it and have the money, skip the cactus triggers and look at the Elinchrom Skyports. Way more reliable than the ebay triggers. If you're really serious about it and have lots of money, Pocket Wizard Plus II's are the industry standard.
  5. Phazan
    Phazan TPF Noob!
    Dec 26, 2006
    737
  6. Mike_E
    Jan 26, 2007
    5,327
    264
    You could do a lot worse than a Metz 45.
    Check which ones are safe using a PC cord. If you go wireless it won't matter but they have brackets which work pretty well for event photography that you don't want to bother with a stand.
    The Auto function is amazingly consistent too. ;)
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
  8. Phazan
    Phazan TPF Noob!
    Dec 26, 2006
    737
    Hey, thanks for the replys. I don't know what a PC chord is, though. I'm so confused about everything... all I want is a decent, wireless, off-camera flash set-up that $150 will buy me.
    I even looked all over strobist.com, and couldn't find a clear answer.
  9. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
  10. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    My wife picked up a Promaster with a Canon module for her EOS630 (works with Elan's). I beleive it worked on the D-SLR's as well. Right around $120 w/ the module, if my shaky memory serves my properly.
  11. Phazan
    Phazan TPF Noob!
    Dec 26, 2006
    737
    I'm confused on how to tell if the flashes are compatible with my camera. I don't want to take any chances of somehow breaking anything...
  12. Applefanboy
    Applefanboy TPF Noob!
    Feb 13, 2008
    156
    Flashes are all compatible with your camera as long as they have a trigger voltage that your camera can handle. Older flashes usually have a 100v - 300v trigger voltage which will fry a 40D or any digital camera. As long as the trigger voltage is under 8 volts, it should be alright. I would strongly recommend the Vivitar 285hv. I just got one and love it!!!
