Flash shadows
Discussion in 'Critique Forum Archives' started by colintinto, Aug 10, 2005.
  1. colintinto
    colintinto TPF Noob!
    Jun 9, 2005
    54
    Hi All,
    I took the attached picture with my 300D, using the built in flash. The wall behind was at least 6 or 7ft away, but I've still got a big nasty shadow. I guess the simple answer is to take the picture without the flash, in fact I did that and it came out OK, but in some situations that's not possible, especially when trying to take candid shots where the subject might move, making a longer exposure impossible.
    Would a proper flash unit be able to control the brightness a bit better than the built in one? Any other suggestions?
    I guess I could also photoshop out the shadow...
    [​IMG]
    Colin
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    You could try using a faster shutter speed...up to the fastest sync speed...which would reduce the exposure of the background.
    You could try using a wider aperture to shorten the DOF and render the background out of focus.
    You could use a shoe mounted accessory flash that is higher above the lens than the pop-up....may not be better in a vertical orientation though. You could use an off-camera flash.
    A flash bracket is often used to mount a flash high above the camera so as to better light the subject and throw the shadows downward and hopefully out of the picture.
  3. Tally Ho
    Tally Ho TPF Noob!
    Jul 1, 2005
    111
    9
    A faster shutter speed will only make it worse, as it will prevent any ambient light from 'piling onto' the background and lightening it up. A wider aperture won't help either, especially at this distance. A flash bracket would help however.
    Tally Ho
  4. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    If the subject was further away from the background he would create less of a shadow. Try using your flash on fill, slow or rear. This will mix the ambient light with the flash.
