flash sync speed
Discussion in 'Beyond the Basics' started by Mitch1640, Mar 22, 2009.
  1. Mitch1640
    Mitch1640 TPF Noob!
    Jul 10, 2008
    180
    does anyone know if the d90 has high speed flash sync or am i stuck at 1/200. and what is FP high speed sync?
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Don't be afraid to read your camera manual. If you have lost it, you can download for free, the manual from the Nikon website.
    The answer is... yes it has it.
  3. Village Idiot
    Mar 20, 2008
    7,274
    406
    It doesn't.
    The flash does, but the camera will always have a set sync speed. So an SBXXX may have a high sync speed mode, but unless you have a special flash with that option, the D90 will only fire up to it's x sync without getting black bars. AFAIK, Nikon has not went back to the electronic shutter design that allowed the camera to have a really high x sync.
  4. JerryPH
    Oct 14, 2007
    6,111
    15
    Hang on... the D90 doesn't have support for FP high speed sync? I would be very surprised to hear that. I am in a location that doesn't support downloading, but tonight I will download the manual from Nikon and check that out... I am almost willing to bet money that it does support high-speed focal point sync but you have introduced some doubt into my mind. If it does, which I am feeling it does, yes, of course one has to use Nikon flashes to access this feature... or one could use the new Pocket Wizards and get up to 1/500th sync speeds with ANY flash.
    I'll come back with a "yea" or "nay" for sure tonight on this.
  5. Village Idiot
    Mar 20, 2008
    7,274
    406
    Semantics? The D90 supports the high speed sync on Nikon speed lights, but the D90 itself does not have high speed sync mode. If he's using a flash that does not have high speed sync, then the D90 will not go over it's x sync.
    The PW modifies this. It doesn't change the fact that the x sync on the D90 is 1/250, iirc. It's like using a set of cactus triggers; you might not be able to shoot over 1/160 without getting the black band but that doesn't change the camera's rated x sync.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Perhaps. :)
    The D90 has a leaf shutter, that means that it is 1/250, if it is electronic, it can do 1/500th with any light. It's native sync speed may indeed be 1/250th, but that doesn't mean that he has no options to get above that, this is what I will find out tonight.
    I understand how sync works, I just want to clarify (to myself more than anything) if I was right.
    - does the D90 support CLS and therefore sync speeds up to 1/8000th
    - leaf or electronic shutter? I believe leaf and hence native 1/250th
    The op did not specify flash brand or even if he had a flash other than the on camera one. Downloading the manual will answer those all for me tonight.
    As far as what the PW does, it doesn't modify anything, but it does "adjust" the TTL timing so that you can get full flash power with anything (studio strobes included) at up to 1/500th shutter speeds. Its not black magic, just a simple fact that most flashes are a lot faster than 1/500th in duration and hence if you play with the timing, should be able to adjust it so that full power is possible at 1/500th without banding at the bottom or loss of lighting strength.
  7. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    So with PW's, can you shoot higher than your camera's x-sync, or will it still only let you shoot up to it?
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Well according to PW, you can get up to 1/500th with almost any camera and any flash (studio strobes are included in that list and the 5D mkII is the current exception), irrespective of if your native sync speed is 1/160th, 1/200th or 1/250th. It has to be in TTL mode only, though.
  9. Village Idiot
    Mar 20, 2008
    7,274
    406
    Why does it have to be in TTL mode? Most flashes don't have a TTL mode.
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Don't ask me, ask PW. :lol:
    Thats a requirement for some reason. I think it has something to do with the way the PWs work and their timing of the flash and what not.
    I am hoping this changes by the time they release the Nikon versions. :)
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    All cameras have a bit of give in their sync settings to accommodate older slower flashes not keeping up with a strict 1/250th time. Think about all the electronics that go in for instance wireless-CLS and you'd see why a bit of give and take is important when syncing a flash.
    Btw the D90 definitely does not have a leaf shutter. It has a vertically travelling focal plane shutter just like every other DSLR.
  12. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    leaf shutters are usually in the lens of large format cameras, I think some MF cameras (rollie) also had leaf shutters but I have yet to hear of any 35mm or digital come with a leaf shutter. H
flash sinch speed d90
