Just be aware that if you incorporate the 430EX, you will need to use it in manual power mode because in E-TTL, it uses a preflash which will mess with your optical triggers.thanks for the advice, maybe i will do that, and if i need more power i can use the 430 on an off camera bracket with a hotshoe cord, and use the peanuts for the 383s.
That depends on a lot of factors. Like what you are shooting, how far away the lights will be and the aperture you will be shooting at.do you think i'll have enough power without the 430?
When I first started doing 'in-home studio' shooting, I had one B800 and a couple cheap flash units with optical slaves. It did work most of the time, but I really began to despise the flash units because of their slow recycle time. This was especially bad when shooting kids.For the money im spending on slave flashes i might as well get another stobe from AB.
