Flashes etc.
Discussion in 'Photography Beginners' Forum' started by Ptyler22, Jul 21, 2008.
  1. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    So After a loong search I finally ordered a Canon 40D, with it I got the 28-135mm kit lens, canon 50mm F1.8, extra battery, lens hood for the 28-135, 2 8gb cf cards, and a lowepro backpack case. I got all this for $1388. Do you think that is a fair price to pay or was it too much, I ordered it all new. I also was wondering if there are any other things you think I will want with this stuff, like flashes, filters... I shoot mostly sports and other things, but for now I am not doing portraits or anything, but I might if I decide to try and promote a buisness or what not. Any suggestions? Thanks
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That price sounds pretty good for all that stuff.
    A flash could come in very hand, depending on the type of shooting you will be doing. I suggest the 430EX or the 580EX.
    One thin you seem to be lacking is a wide angle lens. I don't know why Canon is selling the 28-135mm lens as a kit with the 40D...it's much to long, in my opinion. I would suggest something that starts in the 17-18mm range.
  3. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    OK, Can I pick one of those up new or used for less than $100, like maybe a 17-42 or something like that?
  4. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    What about a battery grip, do they come with batteries in them? or can I just put the 2 batteries I have in them?
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    The cheap option for a wider lens would be the usual Canon kit lens, EF-S 18-55mm. Everyone hates them so they can be had for dirt cheap. They are OK but not great. The best option would be the Canon EF-S 17-55mm F2.8 IS. But it's almost as expensive as the camera itself. I have the Tamron 17-50mm F2.8, which is a nice compromise between price and performance.
    As for a grip, I don't think they come with batteries. But yes, you could put your two camera batteries into a grip...or even just one at a time...or 6 AA batteries.
  6. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    is it worth it to just have the batteries in the grip instead of having to switch them out?
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It really depends on a lot of things. I don't have a grip, and I could probably shoot a whole wedding without changing the one battery in the camera. So A grip with two batteries would be more than I would need. That being said, a bigger lens with IS, will use up more power, using the screen a lot will use up more power etc. So it really depends.
    To me, the biggest advantage of the grip is how it feels.
  8. Zansho
    Zansho TPF Noob!
    Jul 13, 2008
    76
    Indeed. Biggest advantage is the real estate the grip offers when you're shooting. I have both of my cameras with grips, and I'll never go back without.
    I also believe the grip adds more FPS with two batteries in the grip? I could be wrong, not 100% sure on that one.
    You can pick up some used 430 EX's for cheap if you know where to look - places like KEH is a good place to start.
  9. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    I got 2 transcend 8gb 133x write speed cards. I am assuming that these will work on a 40d right? also if they do work how many pictures you think I can get from a burst with it? anybody use one on their 40d?
  10. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That's true of some Nikons...not Canons though.
    As long as they are CF cards, they should work just fine.
    The number of photos you can shoot in a burst, is more dependant on the camera's internal memory buffer, than on the card. It also depends on the recording mode (RAW will be a fair bit slower than JPEG). Once the buffer is full, then the shooting rate will slow down as the camera writes the files to the card. This is where the speed of the card comes into play. But for normal shooting, including short bursts, is the camera not the card that matters. The 40D should be really good in that regard.
  11. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    sorry, OT:
    holy crap, mike! how do you not get carpel tunnel shooting weddings without a grip?!
    :hail:
  12. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    The grips on my 20Ds are a fair size and feel pretty good.
    Plus, I use the short ends of my OP-Tech straps as wrist straps.
    I would buy a grip, but I just can't seem to justify the price. I'm sure that once I used one for a while, I'd love it...but I'm just not there yet.
