Flashgun Question
Discussion in 'Photography Beginners' Forum' started by stoi689, Aug 19, 2010.
  1. stoi689
    stoi689 TPF Noob!
    Sep 2, 2009
    20
    Belfast
    Hi guys!
    I was at the boxing the other night watching some of the ringside photographers snapping away at the action and I noticed two photographers standing next to one another with their flashguns being used in an interesting way.
    The camera was pointing between the bottom and first rope, with flashgun pointed upwards at sort of a diagonal angle (I'm assuming to avoid that dark strip from flash hitting the rope). I also noticed a small, seemingly metallic, strip attached to the flashgun. Not sure if that was for bouncing the light off somewhere or what.
    I have a flash myself but as a complete novice have never truly mastered the art of ringside photography and am keen to hear any explanations of this use of flash!
    Thanks guys. Stoi. :thumbup:
  2. Misfitlimp
    Misfitlimp TPF Noob!
    Jul 8, 2009
    375
    Fillmore, CA
    Im not too sure if I got what you where describing but if the flash was on camera and was at like a 45 it was prolly so he wouldnt get the gnarly harsh flash shots
  3. LCARSx32
    LCARSx32 TPF Noob!
    Jun 8, 2010
    641
    Cedar Hill, Missouri, USA
    Like the post above says, they were probably trying to avoid harsh shadows and highlights. The metal piece you saw attached to the flash was a bounce card, maybe? Someone with more flash accessory experience want to chime in?
  4. JasonLambert
    JasonLambert TPF Noob!
    Apr 16, 2010
    737
    14
    Hermitage, PA
  5. stoi689
    stoi689 TPF Noob!
    Sep 2, 2009
    20
    Belfast
    Yes Jason that is exactly what it looked like!
    What are the benefits of using one of these?
  6. edouble
    edouble TPF Noob!
    May 24, 2009
    732
    10
    NEPA
    This is another method of incorporating bounce flash. The small card that is typically included with a speedlight style flash is not effective enough for directing light into a large area like a boxing ring. This is a very popular tool for defusing light to make it softer and less harsh. Softer light adds texture and reduces glare which is much more appealing than direct flash lighting.
  7. stoi689
    stoi689 TPF Noob!
    Sep 2, 2009
    20
    Belfast
    Many thanks for the informative response edouble. I think I might buy on of these cards, I don't think they will be too expensive.
  8. stoi689
    stoi689 TPF Noob!
    Sep 2, 2009
    20
    Belfast
    Hey people, I was taking a glance at my own flashgun and would you believe it, there seems to be a built-in light bouncer! It slides out of the top and has two parts - a plastic piece and a see-through part.
    So if anybody else is curious (or just stupid like me), check out your own and see it may be already built-in.
  9. edouble
    edouble TPF Noob!
    May 24, 2009
    732
    10
    NEPA
    The "see thru" part is a small diffuser to help spreed light when the flash is set to a wide setting like 14mm. The white card you found is a "bounce card" which can help illuminate a subjects face at relatively close distances without having the flash directly pointed at your subject.
  10. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    rather than spend money, the same can be achieved with some heavy weight paper (try colors for a fun effect) and a rubber band. :D
