Focal Length vs DOF: Revisited
Discussion in 'Photography Beginners' Forum' started by jamesino, May 18, 2008.
  1. jamesino
    jamesino TPF Noob!
    Dec 9, 2007
    115
    So far, I've been comfortable with my knowledge of the Depth-of-field effect of photography. The DOF is solely a factor of the focal distance and aperture, except in Macro photography, where the pupil magnification also plays a factor.
    Most tutorials say that the focal length does not technically effect the DOF because if you were to keep the object the same size, you will see the same DOF as a lens of a different focal length. For example, if you were to take a picture of an object from 10m away with the same aperture, one with a 50mm lens and the other with a 100mm lens, the 50mm lens will look like it has a greater DOF. But if you were to keep the subject size the same, ie walk closer with the 50mm, you will see that the DOF is the same.
    However, to keep the subject the same, one lens, the shorter one (50mm), has to be closer (shorter focal distance) to the object. Since the focal distance affects the DOF, is it not the decreased focal distance that is reducing the DOF to the same level as the longer lens?
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
  3. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    Yes. Why "revisit" a topic that has already been beat to death?
  4. evo5gsr
    evo5gsr TPF Noob!
    Feb 6, 2008
    131
    Bay Area
    So we can beat it up some more. :p
  5. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    You arent saying this this is
    [​IMG]
    Are you Socrates?
focal length vs. focal distance
