Focus Stack Question
Discussion in 'Macro Photography' started by mwilson263, Oct 27, 2017.
  1. mwilson263
    mwilson263 TPF Noob!
    May 15, 2017
    56
    13
    I’ve tried doing a focus stack a few times lately on macro images, but have hit a snag each time. Each image I took at a different focus point seemed to have a slightly different focal length and I haven’t been able to effectively align the images together. The first time I thought maybe I bumped my tripod or camera, but as it recurred I did a bit of research & learned something I didn't know before. If I understand, even on a fixed focal length lens (in my case 100mm macro) the focal length will change just a bit as you change focus. As I think it through it makes sense to me, but if I’m misunderstanding the explanation somebody please set me straight.
    So now knowing why it’s happening, how do I get around it with focus stacks? I’m using Photoshop Elements which I understand isn’t as powerful in putting images together as Photoshop CC, so maybe it can’t be done in Elements. I’ve searched a bit on Google and looked at a few Youtube videos, but haven’t found anything to get me past the focal length issue. Anybody here work with focus stacking who can point me in the right direction?
    Thanks,
    Mike
  2. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,547
    8,088
    Iowa
    Try a different app. I've had no issues with CombineZN or Picolay.
  3. snowbear
    snowbear Big Furball Supporting Member
    Dec 9, 2006
    12,781
    4,432
    SoMD
    I've done focus stacking once and , I guess, Photoshop CC adjusted it all for me.
    Maybe the best way then, is to leave the lens focus alone (my 105mm has a lock) and use a focus rail - then you just move the camera/lens closer or farther.
  4. smoke665
    smoke665 TPF Supporters Supporting Member
    Mar 29, 2016
    4,708
    1,901
    Alabama
  5. 480sparky
    Mar 8, 2011
    22,547
    8,088
    Iowa
  6. mwilson263
    May 15, 2017
    56
    13
    Thanks for the help. I'll look into these and keep plugging away. :)
  7. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,680
    386
    I use Zerene Stacker. I don't have a rail so just do manual adjustment of the focus. The program makes the adjustments for the slight change in size as the focus is changed. Usually it does very well using the defaults, but there are a number of options to refine the stack.
  8. Overread
    May 1, 2008
    23,945
    4,126
    UK - England
    Try Combine ZP its 100% free to use
    CombineZP. Get the software safe and easy.
    Otherwise there's Zerine Stacker and Helicon Focus - both paid software but also do focus stacking very well.
    In general stacking is one of those very few editing areas where different software can give drastically differnet results. What might fail in one will work in another due to the subtle differences in how the code stacks up the photos.
    Most should be fine with the tiny amounts of focal length adjustment as you change focus and I've never found a firm article that states that there's any significant gain using focal length changes (ergo changing the focus point) over changing the distances involved between the two subjects.
  9. k5MOW
    k5MOW No longer a newbie, moving up!
    Oct 13, 2015
    225
    74
    Friendswood TX
    Photoshop CC will align everything automatically. I’ve had no issues at all.
    Sent from my iPhone using Tapatalk
