Focus
Discussion in 'Photography Beginners' Forum' started by EleanorW, Aug 16, 2009.
  1. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Saskatoon, Saskatchewan
    I am finding that I'm struggling a bit with focus. I'm getting better, but still having troubles.
    I take the pictures, think I got them right and when I get home and upload them, I'm finding they're off just a little (or a lot) sometimes. Is this something that will just get better with practice? The good news I see this morning as I upload my latest batch is my exposures are almost perfect - no more clipped highlights yay lol.
  2. Opher
    Opher TPF Noob!
    Aug 7, 2009
    448
    5
    Kitchener ON
    Are you using manual or auto?
    If you are using auto than manually select you focal points. Also you should be aware of your DOF (watch your aperture).
  3. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    I use auto (and I try to use either program or aperature setting) until I get annoyed with it's constant readjusting... then I switch to manual for a few shots. I've been taking 2 or 3 shots each time with different aperatures to learn how they relate to each other (ie numbers vs results I see)
  4. KmH
    Apr 9, 2009
    40,536
    5,541
    Iowa
    Are you sure it's focus and not camera shake?
    Pro's don't often make images while hand holding their camera. They use a tripod.
    What focus mode is your camera set to AF-S, AF-C, AF-A?
  5. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    I have the camera set to AF-S and I was on a tripod the whole day, using a remote. It must be me then :)
  6. Gaerek
    Gaerek TPF Noob!
    May 2, 2009
    1,341
    98
    Sitka, AK
    Does your camera automatically pick the focal point, or have you manually selected it? If the camera picks the wrong focal point, your subject will almost always be out of focus. If I'm hand holding, I'll manually select the center point, half depress the shutter with the center on my subject, recompose, then fully depress the shutter.
    On a tripod, I choose whatever focal point that covers my subject, half depress to get focus, then turn on manual focus so the focus doesn't change. Could that maybe be your problem?
  7. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Gaerek - I didn't know that I could use the auto focus, set my shot and then switch to manual. That actually makes a lot of sense. All my pictures from the last set are of flowers and it was a windy day, which I didn't think about until just now. The wind likely moved the flowers and the camera reset the focus on me. I sure have a lot to learn yet :)
  8. Soocom1
    Soocom1 TPF Noob!
    Feb 27, 2006
    533
    Southwest US
    Something I discovered quite by accedent.
    Set your Dioptler adjustment (if you have it). For some unknow reason it changed the quality of the pics I was taking.
    Also, it is possible that the lens could be out of calibration as well.
  9. EleanorW
    EleanorW TPF Noob!
    Aug 10, 2009
    271
    Ok I went out today and here are 2 examples of my troubles with focus - I'm pretty sure it's me and not the camera :D
    #1 f6.3, 1/125, iso 100, program priority
    [​IMG]
    #2 f8.0, 1/640, iso 100, program priority
    [​IMG]
  10. Cely
    Cely TPF Noob!
    Jul 22, 2009
    94
    MI
    What is the focal length on your lens, and also what is the minimum focusing distance? How close were you?
    Number one looks like you were too close to focus on certain parts of the plant.
    Number two looks like it was the same thing.
