Focusing rial for macro photography
Discussion in 'Photography Equipment & Products' started by avilamillar, Nov 7, 2009.
  1. avilamillar
    avilamillar TPF Noob!
    Jan 1, 2009
    194
    Cambridge, MN
    Hi, i was looking for a focusing rial and i saw this one:
    Manfrotto by Bogen Imaging | 454 Micrometric Positioning | 454
    Do you think it will do a good work?
    also i dont know if i just need to put that thing in the tripod or how does it work?
    thanks
  2. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    It will work fine. And yes will need to be on a tripod. It has a 1/4 -20 thread for tripod mount in the bottom.
    BUT....
    I would suggest this one instead. It gives you 4 way movements for better alignment control.
    MFRS Adorama Budget Macro Focusing Rail Set with 4 Way, Fine Control, Camera Focusing Rail for Macro Photography.
    Little less expensive too. We have one and use it quite a bit. Had it for about 3-4 years now and no signs of weakness. Should last a long time.
  3. avilamillar
    Jan 1, 2009
    194
    Cambridge, MN
    thanks :) so i dont need a head for the tripod+the focusing rial right?
    the one you showed me looks better thanks again
  4. Rifleman1776
    Rifleman1776 TPF Noob!
    Jan 4, 2009
    182
    Mountain Home, Arkansas
    I checked out this thread just to learn what a 'rial' is.
    Still don't know.
    But, I have seen focusing rails before.
  5. benhasajeep
    May 4, 2006
    4,021
    494
    You will still need a head of some kind so you can get the camera pointed in the general direction. Up / down, pan left / right. This rail just lets you fine focus and center left to right. A head is still needed. But can be any head really. You could get away without a head by adjusting the legs but that would be a pain.
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    i've seen two types of rails:
    Some are designed so that the camera slides freely until knobs lock into place via a clamp. Some are designed with two knobs. One knob turns a worm gear that can readjust the camera forward and backwards with precision with another knob to lock into place.
    Personally (I'm not an expert in macro though), I would rather get the one that allows for precise adjustments via gearing. Like this one:
    Velbon | Super Mag Slider | SMAGSLIDER | B&H Photo Video
    over the ones linked above. You will need a head of some sort... i recommend a stable and precise 3 way head.
