foggy lens
Discussion in 'Photography Beginners' Forum' started by Christina, Aug 26, 2007.
  1. Christina
    Christina TPF Noob!
    Jul 19, 2007
    947
    jacksonville, fl
    ever have the problem of going fo indoor to outdoor and your lens fogging up? I came across this the other day and was curious of the best way to cure the problem so you can getting back to shooting!
    any ideas or thoughts?
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    There is nothing really that you can do.
    The 'fogging' is caused in the same way that mist is - cold meeting hot and humid.
    If the lens is cold and you go into a warm humid environment the water condenses onto the lens.
    You can get it from going outdoor to indoor or vice versa depending on conditions. And the temperature difference does not have to be much if the humidity is high.
    You can get treatments to put on glasses and windscreens to stop them misting up and they do offer a short term solution. But it is not advisable to coat camera lenses with stuff - best to keep them as clean as possible.
    The easiest and best solution is to let the camera aclimatise for a few minutes. The lens may mist up but if you leave it it usually clears after a minute or so on it's own. Try to resist the temptation to wipe it clean.
  3. pink_panther
    pink_panther TPF Noob!
    Aug 26, 2007
    76
    UK
    HI
    A little tip I use for night shooting and colder climates is to get hold of those little pocket warmer sticks that you can buy in outdoor pursuit and camping shops. You can wrap these in some material and attach them to your lenses around the body of the lense - This will keep the lense at a warmer temperature than ambient - thus stopping "fogging" of the lense.
    It works for me.
  4. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    I think this will work. Put your camera in a freezer bag and seal it before going from cold to warm temps. Let it reach the ambient temp before opening.
    I've heard this works, I have not tried it.
    Edit: I'm pretty sure this is only a problem going from cold to warm, vice warm to cold.
  5. Christina
    Christina TPF Noob!
    Jul 19, 2007
    947
    jacksonville, fl
    thanks for the tips
  6. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    Cold Weather Shooting
    This thread I started, should give you your answer.
camera lens foggy cold
canon lens fog because the cold wether
cold temperature foggy camera lens
digital camera foggy lens from cold
dslr foggy cold
dslr lens fog cold to warm
foggy lense
how to prevent camera lebs fog in cold
preventing foggy lens in the cold
