For Sale Sekonic L-358 Light Meter - LOW PRICE!
sdettloff
Used for only one shoot!!! Used Sekonic L-358 light meter. I don't have the box or manual, however, the manual can be downloaded from the Sekonic website. I'm selling SUPER cheap compared to others for $170 SHIPPED.
L-358 FLASH MASTER - Technical Specifications
Type: Digital exposure meter for ambient and flash light
Light receiving method: Incident light and reflected light
Incident light: Convertible to flat diffuser (Lumisphere in down position)
Reflected light: Light receiving angle 54° (Lumigrid)
Light receptor element: 2-Silicon photo diodes (incident and reflected)
Metering modes
Ambient light: Aperture priority metering
Shutter priority metering
EV metering
Flash: With synchro cord (cumulative and non-cumulative)
Without synchro cord (cumulative and non-cumulative)
Measurement using the optional wireless flash radio triggering system (cumulative and non-cumulative)
Radio Triggering (Optional)
Radio technology: Complex 16/24 bit digitally coded
Range: Up to 100 feet from transmitter to receiver
Channels: 1 to 16 channels standard, 17 to 32 “Quad Triggering”
Radio wave frequency:
USA & Canada (FCC & IC) CH1-CH16 344.00MHz CH17-CH32 346.50~354.00MHz
Europe (EU) CH1-CH16 433.62MHz CH17-CH32 434.22MHz
Measuring Range (ISO 100)
Ambient light: Incident light EV-2 to EV 22.9
Reflected light EV-2 to EV 22.9 (with 54° Lumigrid)
Optional Spot: 1° EV5 to EV 24.4
5° EV3 to EV 24.4
10° EV2 to EV 24.4
Flash: Incident light f/1.0 to f/90.9 (approx. f/124)
Reflected light f/1.0 to f/90.9 (approx. f/124) with 54° Lumigrid
Optional Spot: 1° f/8.0 to f/124
5° f/4.0 to f/124
10° f/2.8 to f/124
Repeat Accuracy: +/- 0.1 EV or less
Calibration Constant
Incident light metering: Lumisphere C = 340
Retracted C = 250
Reflected light metering: K = 12.5
Display Range
Film speed: ISO 3 to 8000 (in 1/3 steps)
Shutter Speeds: Ambient light: 30 minutes to 1/8000 seconds (in 1, 1/2 or 1/3 stop) plus 1/200, 1/400 Cine speeds: 2, 3, 4, 6, 8, 12, 16, 18, 24, 25, 30, 32, 36, 40, 48, 50, 60, 64, 72, 96, 120, 128, 150, 200, 240, 256, 300, 360 frames per second (at a 180° shutter angle)
Flash: 30 minutes to 1/1000 second (in 1, 1/2 or 1/3 stop) plus 1/75, 1/80, 1/90, 1/100, 1/200, 1/400
Aperture: f/1.0 to f/90.9 (in 1, 1/2 or 1/3 stop)
EV: EV -9.9 to EV 40.1 (in 1/10 stop)
Analog scale
Aperture: f/1.0 to f/90 (in 1/2 stop)
Shutter speed: 2s to 4k (1/4000) (in 1/2 stop)
Other features
All-weather feature: JIS standard water resistance class 4, splash-proof type
Memory function: 9 readings on analog scale (f/stop & shutter speed) with memory recall and clear feature
Multiple Flash function: Unlimited flash readings (only one digit is displayed when the cumulative number is ten or more.)
Average function: Up to 9 readings can be averaged
Brightness Difference function: +/- 9.9 EV (in 1/10 stop)
Flash analyzing function: 0 to 100% in 10% in increments
Exposure Out of Range: U (underexposure) or O (overexposure) indication
Exposure compensation: +/- 9.9 EV (in 1/10 steps)
Calibration compensation: +/- 1.0 EV (in 1/10 steps)
Battery Power Indicator display: With 3 level status icon
Auto Power Off: 20 minutes after last use
Auto illumination: EV 6 and under
DIP switch mode selection: Located under battery cover
Second ISO film speed setting: ISO 3 to 8000 (in 1/3 stop)
Battery used: One CR123A battery (3V Lithium dry cell)
Operating temperature range: 14° to 122° F (-10° to 50° C)
Storage temperature range: -4° to 140° F (-20° to 60° C)
Dimensions: 2.4"W x 6.1"H x 1.5"D (60mmW x 155mmH x 37mmD)
Weight: 5.4oz (153gm) with battery
Standard accessories supplied: Lumigrid, soft case, strap, synchro terminal cap, CR123A Lithium battery
Optional accessories:
Cat# 401-361 1° Spot Attachment
Cat# 401-362 5° Spot Attachment
Cat# 401-363 10° Spot Attachment
Cat# 401-855 Case for Meter with Spot Attachment
Cat# 401-515 Mini Light Reception Unit (12mm Lumisphere)
Cat# 401-621 Transmitter Module
Cat# 401-801 Synchro Cord (3-way, 5 meter long - connect camera, light meter and flash)
Cat# 401-801 Folding Stand-Up Gray Card
