format card from two camera bodies
Discussion in 'Beyond the Basics' started by ann, Aug 9, 2009.
  1. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    usually i am very careful about using the same card in two different camera bodies, but alas and alack even the best intention can go astray.
    Is there anyway to accomplish a "full wipe" with just one body, or it is just important to insert card into each camera body?
    It seems as if there are different folders for each type, but it seems the folder remains (without image).
    I was testing some bodies and lenses the other day and the card shows each camera body, and even when formating the card i can't seem to get back to the recommended number of images available on the card.
    hope this makes sense.
    :grumpy:
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    The answer is yes. The procedure depends on what camera you have. Your manual will definitely have the answer for you.
  3. ann
    May 14, 2007
    4,263
    189
    thanks jerry,
    heaven forbid i look at the manual :lmao:
    one would hope a d700 could do this since it can practically go to the moon.
  4. JerryPH
    Oct 14, 2007
    6,111
    15
    D700... press and hold the MODE and DELETE buttons togther for 2 seconds until the word FORMAT appears and flashes in the top LCD. Release the 2 buttons, then press and immediately release them again AT THE SAME TIME... wait 2-3 seconds... Bob's your uncle.
    You could do this same thing from the menu. I'll let you read the manual for that... it is something you SHOULD do always. ;)
    (thats kind of an embarrassing question to ask being a D700 owner and not really "beyond the basics"... lol)
  5. Aye-non Oh-non Imus
    Aye-non Oh-non Imus TPF Noob!
    Nov 18, 2007
    516
    23
    I have this issue with a couple of different cameras and cards also. The folder of one remains when in the other. I was goinig to go to the root directory of the card and delete the empty folders and then reformat, but I really don't consider it too much of an issue.
    Unnecessary dude. The only bad question is the one not asked.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    On Nikon cameras, this is a simple safety feature so that you don't delete shots taken with your (for example) D200 when reusing the card on your D700. The method I outlined wipes all folders on the card.
    A little necessary. That question really was a beginner question EASILY answered with a 10 second look through the manual's index. That is about how long it took me to find it the first time (2nd day I had the camera), at least. I bet it took longer to type the question than to find the answer. :)
  7. ann
    May 14, 2007
    4,263
    189
    i was testing the d700, d300 and my old trusty d100,
    no decision yet on what will replace the 100, but there is always the online manual.
    which i did forget
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Even faster, the PDF document from Nikon... makes searches a breeze. They keep manuals in PDF format online for most everything going back as far as the 70s. :)
  9. ann
    May 14, 2007
    4,263
    189
    ok,
    i realized i did know how to format a card, i usually just use the menu function, not the method jerry recommended. (which i did, before posting)
    however, the files from a fuji s9100 won't go away, unless i use the fuji camera and even then a folder remains .
    so it seems for what ever reason, the format is camera specific.
  10. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    I guess what I don't understand here is with the cheap price of memory, why not dedicated cards for dedicated bodies? No fuss no muss.
  11. ann
    May 14, 2007
    4,263
    189
    i would agree, however, it was an accident, at least for the fuji vs nikon.
    but with the testing, i just took along one card; with the thought of testing out three lenses with the camera bodies as an after thought.
    i thought perhaps there was a secret hand shake that would allow one to format the entire card in one body, but that doesn't seem to be possible.
  12. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Did you ensure you had Quick format selected?
