found an old camera
Discussion in 'Photography Beginners' Forum' started by PiMpPiStOl, Mar 5, 2007.
  1. PiMpPiStOl
    PiMpPiStOl TPF Noob!
    Oct 29, 2006
    57
    http://www.deviantart.com/deviation/50245865/
    wondering if thats still a good camera, andif anyone knows how to use it....i dont know how to get the film out. cuz im pretty sure all the film is used. i remember i use to play around with it alot when i was littler. and i found it again today, and since i just kinda got into photography, it might be a good camera...but im not sure! maybe someone can help? please?? i just need to knwo if its still a good camera for taking pics! thanks!!!!!!
  2. TBaraki
    TBaraki TPF Noob!
    Jan 17, 2005
    718
    4
    Edmonton, Canada
    If it works it is a great camera.
  3. PiMpPiStOl
    Oct 29, 2006
    57
    awesome! how do i know what kind of film to buy for it though?
  4. TBaraki
    TBaraki TPF Noob!
    Jan 17, 2005
    718
    4
    Edmonton, Canada
    Film choice really depends on what you want to be shooting. If you're just figuring out the camera, and don't really know what you want, start with whatever is cheap.
    The get the film out, by the way, there is a button you hold on the bottom of the camera while winding the black and metal knob labeled "R" in the direction of the arrow. After you feel the resistance drop, pull that knob straight up and the back will pop open.
  5. jiconlin
    jiconlin TPF Noob!
    Jan 19, 2007
    Lansing, MI, USA
    That is a K1000, a really good first camera for many photographers out there. To get the film out, (looking at your photo.) flip up the silver lever of the right side dial and rewind the film. Do this slow, cause if you go fast you can actually create sparks in the canister. (You may have to push in a button, usually on the bottom of the camera to get it to let you rewind it.) Once you get it rewinded (sp?) Pull that lever up and the film door back should pop open. It's been a long time since I have handle a K1000, but if I remeber correctly, that should give you a good start at getting it reround and out of the camera. Good Luck!
    Also, it's just a 35mm camera, so any 35mm film should work. I can't remeber if you have to manually set the ISO on a K1000 or not, but if you do (you'll see a dial with numbers like 50, 100, 200, 400, 800, etc. (NOT SHUTTER SPEED)) make sure that the ISO is set correctly.
  6. TBaraki
    TBaraki TPF Noob!
    Jan 17, 2005
    718
    4
    Edmonton, Canada
    Right, you do have to manually set the ISO on that camera. Just make sure that the rating of the film you end up using matches the number in the little window on the shutter speed dial labeled ASA.
  7. avcabob
    avcabob TPF Noob!
    Feb 20, 2007
    123
    San Francisco
    If you do a search for Pentax K1000 manual, you can find the manual on the internet and it will tell you what everything on the camera does. It helped me with an old Pentax I found a few months back.
    Also, Pentax never changed the mount it uses for it's SLR lenses, so if you any lenses other then what it's pictured with, you can take them with you if you decided to go digital later on, as long as you stay with a Pentax Digital SLR.
  8. PiMpPiStOl
    Oct 29, 2006
    57
    "Also, Pentax never changed the mount it uses for it's SLR lenses, so if you any lenses other then what it's pictured with, you can take them with you if you decided to go digital later on, as long as you stay with a Pentax Digital SLR."
    so what do you mean? theres a certain kind of lense i have to have if i wanna change it?
  9. TBaraki
    TBaraki TPF Noob!
    Jan 17, 2005
    718
    4
    Edmonton, Canada
    What he's saying is that any lenses that mount to that camera will also mount to any newer film or digital bodies.
  10. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    you can pick up manuals for those cameras for about 5 bucks on e-bay.
    Really helpful.
    Its a great camera :)
  11. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,746
    43
    Ahwatukee, AZ
    How'bout one for free? ;)
    http://www.pentax-manuals.com/manuals/mf/pentax_k1000_manual_s.pdf
    Just type the password Pentax (as you see it here) and there you go!
    Enjoy, that's a good camera to have nowadays, it'll last forever.
  12. Mike_E
    Jan 26, 2007
    5,327
    266
    Once you get the back opened, turn the nob with all the numbers to b-for bulb, cock the shutter and press and hold the shutter release button and then take a flashlight and shine it through the lens (flashlight on one side of the lens and your eye on the other. you can do this with just the lens off the camera, but it's nice to know that the bulb setting works) and make sure that there is nothing on it that looks like dried up salt water or ice or whatever. If there is you'll need a new lens as this is how you check for fungus- a really bad thing and death to a lens for the most part. good luck mike
