FS: Nikon D7100 24.1MP Digital SLR Camera with 55-200 f/4-5.6 VR lens and MORE!!!
drboris
San Diego, CA
Product Information
Grab your Nikon D7100 Digital SLR camera and hit the park, trail, or city for some cool shots. This classy camera boasts a 24.1 MP DX-format image sensor, which means that you should be able to achieve an incredible level of detail with each photo. The image sensor that comes equipped with this body is a full-frame CMOS sensor. As a bonus, the digital SLR camera can shoot up to six frames per second, taking up to a hundred continuous shots. This means that if you're rushing to capture a moment, you have the luxury of snatching as many shots as possible. The Nikon D7100 camera also shoots 1080p video with a full-time autofocus to keep everything clear and an onboard mic to record audio.The autofocus settings found on the camera include contrast detect, continuous, live view, face detection, single, tracking, and more. With a standard USB 2.0 port, all of your pictures can be transferred from the D7100 to your computer or phone in an instant. No matter the quality of lighting in the scene you're shooting, the massive ISO range will allow you to adjust the camera to the perfect setting. The standard ISO range extends from 100 to 6,400 while the expanded range goes up to 25,600. As for memory card types, the Nikon D7100 digital camera accepts SD, SDHC, and SDXC memory types. There are two flash memory card slots available, allowing for more space to hold your pictures. The camera body for this digital SLR comes in a sleek black coloring. If you tend to travel a lot, this Nikon digital camera can be taken anywhere you go thanks to weather-resistance and dust-resistance features. One of the more useful features found on this digital SLR is the inclusion of HDR, or high dynamic resolution. When capturing photos with this setting turned on, colors become more vibrant. You can manipulate these colors even further with the white balance setting. If you are just starting out in photography, the camera is designed so that you will be able to readily use the most basic features. Advanced photographers will find that these cameras open up with a bevy of exciting manual features and settings to tinker with.
Product Features
  • Capture every detail true to life
    The D7100 marks an exciting advancement in image quality for high-resolution DX-format cameras. Nikon specially designed its 24.1-megapixel DX-format CMOS sensor without using an optical low pass filter (OLPF), resulting in the purest, sharpest images using D7100's DX-format CMOS sensor.
  • Speed and precision in harmony
    When the action speeds up, fire a blazing fast 6 frames per second continuously for up to 100 shots. Building on the acclaimed autofocus system from the D300s, the D7100 uses 51 focus points, including 15 cross-type sensors for detecting both vertical and horizontal contrast variations, to achieve fast, precise focus. The central cross-type sensor works all the way down to f/8, a huge advantage when using compatible teleconverters. At the same time, a highly accurate 2016-pixel RGB sensor evaluates every scene, taking into account brightness, contrast, subject distance and color, for spot-on auto operations like Face-Priority and full-time autofocus during video capture.
  • Create movies that amaze
    With full-time autofocus and manual exposure control during video recording, a built-in stereo microphone and an external stereo microphone jack, headphone and HDMI jacks, the D7100 achieves exceptional cinematic reproduction and quality. Dual SD card slots give you additional recording time, and a 60i function enables smooth playback on HDTVs or external monitors.
Product Identifiers
Brand Nikon
Model D7100
MPN 1513
UPC 018208015139
Key Features
Camera Type Digital SLR
Sensor Resolution 24.1MP
Screen Size 3.2"
Optical Sensor
Sensor Type CMOS
Lens System
Lens For SD Body Only
Focus Adjustment Autofocus & Manual Focus
Exposure
Exposure compensation -5 EV to +5 EV (in 1/3 or 1/2 EV steps)
Light Sensitivity 100-6400
Light Sensitivity Max 100
Camera Flash
Flash Type Built-In
Camera Flash Features Auto Flash, Manual
Memory / Storage
Supported Flash Memory SD Memory Card, SDHC Memory Card, SDXC Memory Card
Viewfinder
Viewfinder - Field Coverage 100%
Viewfinder Magnification 0.94x
Dimensions
Depth 3 in.
Height 4.2 in.
Width 5.3 in.
Weight 27.04 Oz.
Display
Display Type LCD
Display Size 3.2"
File Format
Still Image Format RAW + JPEG
Resolution
Max Video Resolution 1920 x 1080
Other Features
Additional Features Autofocus, HDMI, USB
Miscellaneous
White Balance Auto, Cloudy (Preset), Daylight / Sunny (Preset), Flash (Preset), Fluorescent (Preset), Incandescent (Preset), Manual, Shade (Preset)
Exterior Color Black
The D7100 I am selling was purchased from Adorama in 2016 and it is in perfect condition both aesthetically and functionnaly. I have upgraded to a full frame Canon 5D MKIII, so I am selling my Nikon gear. Included with the camera are: an extra Nikon ENLE15 battery ($73 value), an ML-3 remote controller ($20 value), a SanDisk Extreme SDHC 32 GB high speed card ($21 value) and a AF-S DX NIKKOR 55-200mm f/4-5.6G ED VR II lens ($150 value) with a 52 mm Nikon NC filter ($49 value). The LCD displays are protected by a glass (back) and a polymer (top) covers ($50 value). The camera has 14,582 shutter releases out of 150,000 max for which it is rated. This is a great picture taking tool for an amateur as well a pro. The new owner will enjoy it for years to come. Good Luck!
Price: $600.
High resolution pics can be found here: Nikon D7100 - Google Drive
If interested or have questions, please contact me via PM.
