Fuji Velvia 50 35mm. Need some tips and help.
Discussion in 'Film Discussion and Q & A' started by warheit12, Feb 11, 2012.
  1. warheit12
    warheit12 TPF Noob!
    Feb 11, 2012
    29
    Las Vegas
    I am completely new to this forum and I just do photography as a hobby. I am not the best at it but I enjoy it.
    Basically I have a very basic old SLR Canon TX. Max shutter speed of 1/500. slowest is 1 second but I can hold down the button as long as I want as well. 3 lens I have the standard 50mm f1.8 I also have a canon 85 mm f1.8 and finally I have a Rokinon 70-180mm f4.5.
    I wanted to no before I load up this film into the camera. could you guys make any suggestions. I have never worked with 50 iso, so I am kind of worried I am going to screw up every single image because I wouldnt understand the settings. should i get a light meter before shooting this film?
    Thank you all in advance for any help you could give me =)
  2. Rephargotohp
    Rephargotohp TPF Noob!
    Nov 2, 2011
    680
    148
    I've shot a ton of Velvia 50...when I shot film.
    Great outdoor film. Not something you will use for handholding indooors or sports shots. But doing an outdoor (landscape) shot at ISO50 really isn't a problem. Use a tripod if you want to have a deep DOF at a tight aperture. But you have some fast lenses so if you were shooting some detail things outdoors, you certain could get some shuuter speeds fast enough to hand hold.
    Your camera already has a center weighted mneter built bin so use it, unless of course it is broken. Then you could get an inexpensive incident light meter to use.
    Have fiun, colloras on that film are beautiful...well at least I thought so
  3. warheit12
    warheit12 TPF Noob!
    Feb 11, 2012
    29
    Las Vegas
    Thank you for the reply.
    So quick question though. lets say there are absolutly no clouds sunny day. at iso 50 can I get good shots shooting at f1.8? I never really get to shoot at f1.8 and thats why i kind of wanted a low iso film. so would a good shutter speed be about 125-250 at that f stop?
  4. Rephargotohp
    Nov 2, 2011
    680
    148
    Bright sunny day = EV15
    Shooting ISO 50 @ f/1.8 would require a shutter speed of 1/5000 which is beyond what your camera is capable of.
    working it backwards with ISO50 and max shutter speed of that camera (1/500) the minimum aperture you could shoot at in those conditions is about f/5.6
    Shooting at wide open is highly overated but it becomes the mantra of many, even if they can't get 2 eyes in focus at the same time. You could get a 3 stop ND filter if you really wanted to do that on a sunny day
  5. warheit12
    warheit12 TPF Noob!
    Feb 11, 2012
    29
    Las Vegas
    Alright so I guess if I wanted to shoot wide open I would have to have signifcant less light. Well that works, I think I will basically go out and shoot and see how they turn out. Thank you for the help.
  6. michaeljamesphoto
    michaeljamesphoto TPF Noob!
    Dec 15, 2011
    71
    9
    California
    Please don't shoot Velvia (or any other reversal film) without a meter. It would likely just be a waste, considering the small exposure latitude of the film. Basically it's not near as forgiving on exposure as print films. It's too expensive and beautiful to waste without a meter
  7. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    5,577
    716
    Woodbridge, Ontario, Canada
    Looking over your questions/answers ... I have to ask if you know how to use your camera, and it's internal light meter ?
    Have you shot film before using this camera or any SLR ?
    If you do not know how to use the tools ... you should try to understand the basic usage ... if you do not then you probably will not understand our answers.
    http://www.cameramanuals.org/canon_pdf/canon_tx.pdf
  8. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Unlike negative film, it's best to slightly underexpose slide film so that you don't completely blow out your highlights. I typically shoot velvia 50 at iso 80.
  9. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    If you want to shoot at f/1.8 during the daylight than just do it. Color negative film has so much latitude it's ridiculous. Just because it says ISO 100 film, it doesn't mean you have to shoot it at ISO 100. I shoot ALL my color neg at half box speed and it comes out beautiful. Take a look at my blog, the vast majority of it is shot with color negative film way overexposed.
    Seriously, this is where film is 100x better than digital, exposure doesn't need to be perfect. overexpose a stop..whatever, overexpose 3 stops...you can barely tell.
    If you don't believe me, take a look at Jonathan Canlas's book Film is Not Dead. He has an example of Portra 400 over 8 stops, and there is no difference between the normal exposure and 4 stops over. They look identical.
  10. dxqcanada
    Dec 4, 2008
    5,577
    716
  11. BlackSheep
    BlackSheep No longer a newbie, moving up!
    Feb 6, 2011
    1,529
    211
    Woodbridge, Canada
    Switch, I think you misread the OP - Velvia is slide film.
  12. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I agree with Velvia being slide film, but that's not what I posted about. And from what the OP wrote, they purchased Velvia 50 for the lower ISO when they could have just shot whatever CN film at a lower ISO and just went with it. With CN film, it takes alot of overexposure to either ruin it or make it unusable.
can i buy fujifilm velvia 50 in las vegas?
fuji velvia 50
fuji velvia 50 tips
how to shoot fuji velvia 50
how to use fujifilm velvia 50
seattle buy film velvia
shooting fuji velvia 50
tips for shooting velvia
tips for shooting velvia 50
velvia 50
