Fully Manual Or Aperture Priority
Discussion in 'Beyond the Basics' started by LarissaPhotography, Oct 29, 2009.
  1. LarissaPhotography
    LarissaPhotography TPF Noob!
    Dec 27, 2008
    529
    Belleville, IL, USA
    Until recently, I didn't realize that there are professionals using aperture priority. For me, I like the control, so I'm a fully manual guy. Do any of you other pro's use aperture priority?
  2. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    *coughs* There are lots, and lots, and lots of pros that use Av. o_O
  3. Brian L
    Brian L TPF Noob!
    Nov 4, 2007
    374
    Michigan
    Your giving our secrets away man hush!:lol:
    I use manual more then I do av.
  4. battletone
    battletone TPF Noob!
    Sep 22, 2009
    285
    Somewhere in the lower 48.
    This one of those things that I still don't quite understand...
    If using the exposure suggestion from the cameras meter and exposing to the center (0, or the "correct" exposure), then using Av shouldn't make any difference from using manual...expect that in changing light conditions in Manual you will be constantly having to scroll the adjustment wheel. But on a controlled setting, I can see the Manual being a better option, because once you get the exposure you want, you can take multiple exposures with uniformity.
    So basically....my over thinking beginner thought is that outside of a [somewhat] controlled setting and/or intentionally over/under exposing....Manual doesn't really make sense.
    Feel free to correct me where I am wrong...I honestly would like to know how/if my logic is flawed on this. That said...I tend to shoot in M just cause I think it makes me learn more.
  5. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    166
    San Diego, CA (RB)
    I shoot A the majority if the time unless I am trying to control a very unique situation.
    I will shoot S if I M dealing with something I am trying to capture something with good speed.
  6. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    battletone: M is useful in any scenario where the meter is fooled and you need consistent exposures. This can happen often in sports photography.
  7. NiKOnSLR
    NiKOnSLR TPF Noob!
    Sep 12, 2009
    118
    Miami Lakes, FL
    I use mostly A and S.
  8. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    The 'I like full control' argument is a little weak. Even in aperture priority you can dial in exposure compensation.
    There are times manual is needed, but not nearly as often as you might think - or want to believe.
    I ran a poll here recently to find out this very thing... I was amazed at the results. If I recall correctly it was about 70% that used aperture priority followed by about 25% manual and 5% shutter.
  9. Overread
    May 1, 2008
    24,074
    4,172
    UK - England
    battletone you are right - when the camera meter is working and giving you the exposures you want - or simply needs a little correction (eg during daytime light I often find I like to underexpose a little to save highlights) then using aperture priority is far quicker than using manual mode and great for being on the go - walking and such.
    Of course studio conditions, times when flash is the dominant light source and other examples, like at night, then full manual is often the way you need to go because what the camera gives you is not what you want. Take flash as the dominat light source - the camera meter looks at the current light in the scene, whilst hte flash is attached and on the camera can't meter for the flashlight as its not present until you take the shot( at which point its too late to change the settings) so one has to slip into manual mode if the flash light is dominant (ie its providing most of the lighting as oppposed to just filling in a few shadows).
    ALWAYS use the mode that will get you the best shot possile in the situation your in - if for you that is auto mode then use it - if its manual then use that - if its aperture or shutter priority then use those.
    The settings will still give the exact same result - f5.6, ISO 200, 1/320sec is the same in aperture priority mode or manual mode.
  10. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
    +1.
  11. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,335
    Way up North in Michigan
    I'm probably in "A" 90% of the time or more, simply because I usually want to be in control of aperture more than anything, and don't mind as much where shutter falls to make that happen. Then I can dial in the light with EV steps if need be without taking the camera from my eye.
    Next, "M", and that's mostly for studio shots with multiple off-camera strobes. I'm still interested in controlling aperture the most, but the camera meter won't compensate correctly for all the strobes in "A" so I take full control.
    Finally, "T", on the rare occasions that I want to use motion to pan a subject or capture waterfalls or something like that.
  12. joemc
    joemc TPF Noob!
    Oct 14, 2009
    296
    8
    Ft Lauderdale
    I shoot on aperture priority 90% of the time too.....But I use exposure compensation like it's second nature.... That button will wear out first....lol.... I also use the ISO button a million times a shoot to control SS.
    Cheers, joe
do pros use aperture priority
joe mcnally aperture priority
joe mcnally shoots aperature priority
