General critique please
Discussion in 'Landscape & Cityscape' started by DeadEye, May 16, 2007.
  1. DeadEye
    DeadEye TPF Supporters Supporting Member
    May 16, 2007
    960
    11
  2. BoblyBill
    BoblyBill TPF Noob!
    Oct 30, 2006
    2,860
    37
    in the eye of a tornado
    It's a little busy. My eyes are not sure what you want them to look at. It's too bad that the sky got blown out (it's completely white and you won't be able to pull any data from it). However, exoposing for the sky and the ground at the same time is really tricky.
  3. DeadEye
    May 16, 2007
    960
    11
    Thank You
    It was a terrible haze day and took a shot to see what I could get.
  4. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    I get blown out skies around here a lot. Either clear bright blue or in May/June gray and blah. Tried a polarizing filter but the haze is usually still haze. I try to ignore the sky and shoot without it. So I'm with BB also-- too busy, should have gone with excluding the sky altogether and found a subject in the view.
  5. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    After the fact I would crop the sky out.
    While shooting I would use a graduated neutral density filter to even off the exposure between the sky and the ground and in Photoshop use a graduated blue filter to turn the haze into a blue sky.
    skieur
