Getting away from AWB
Discussion in 'Photography Beginners' Forum' started by BLD_007, Jul 28, 2009.
  1. BLD_007
    BLD_007 TPF Noob!
    Jul 27, 2009
    330
    Ok, I have somewhat mastered ISO, Shutter, and Aperture. I own a cannon 50D and I want to start to get away from AWB. I think this will make my pictures much more Sharpe.
    I would like to start to use kelvin temperatures. Is this something you have to learn on the way, or is there as set temp for every thing?
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
  3. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Honestly, You dont need to know the temperatures, You dont change your camera's settings using the temperature, you change your camera's white balance using the Reflected light on the subject (or if you have a Light meter, you meter the direct light?)
    Buy an 18% Greycard and take a shot of that every 5 - 6 pictures your in the same location, if you move, re-shoot the card and set Custom WB.
    Maybe someone else will describe in more detail but im a little busy to describe it in full atm
  4. BLD_007
    BLD_007 TPF Noob!
    Jul 27, 2009
    330
  5. BLD_007
    BLD_007 TPF Noob!
    Jul 27, 2009
    330
    I do need to change my settings on my camera. The cannon 50d has a kelvin setting. This allows me to set the cameras temp setting based on the subject color.
    I might be confused with what you might be saying
  6. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I don't know... I shoot RAW so I can mess with it later if it's bad, most of the time it's great however so I have no desire to constantly mess with another setting.
    Shooting RAW = Cheap Insurance :D
  7. BLD_007
    BLD_007 TPF Noob!
    Jul 27, 2009
    330
    I know, but I take alot of sport pictures. Such as base ball for my schools team.
    My favorite spot it 3rd base because everyone slides in. I get some nice shots, or of them going to home plate.
    Sometimes the green is not a true green of the grass.
    Its hard to explain
  8. PhotoXopher
    May 27, 2009
    3,475
    Yeah, I understand... One option might be if you have a particular need and the setting rarely changes you may be able to dial it in and save that white balance preset (depending on your camera).
    If you really want to get out of auto WB completely you'll need a white balance card at a minimum. I've used white balance lens caps in the past with good results, it's a quick/easy/low cost method worth trying.
  9. benlonghair
    benlonghair TPF Noob!
    Jun 1, 2009
    1,072
    Woodstock, CT
    If you shoot in RAW it's super easy to change the WB once it's downloaded. I went from using auto to selecting it on the fly and now I'm back to auto because it's one less thing to think about.
    And yes, RAWs are large files (mine are 8-10mb) but storage space is cheap.
  10. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    to use the Kevin temperature, you need to know the temperature of the light you using. There are some basic guide lines, however, many who use this method use a color temperature meter which gives the specific K temperature which is then put into the camera, or added to ACR.
    These are very expensive little tools.
    You might be better served to learn to "read" the light conditions your working with and adjust accordingly, or shoot in raw and correct when converting.
  11. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Oh sorry, Disregard my comment then :)
    I didn't know there was ones you could dial it in yourself.
    Learn something new everyday? :p
  12. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    It's a custom white balance preset. Your 450D can hold one. Shoot a grey card so it fills the frame, and then view it in the playback thingamajig, then tell the camera to collect white balance data from that image.
