Getting desperate. How do I get a 35mm Negative enlarged to a 16x20?
Discussion in 'Film Discussion and Q & A' started by keith204, Aug 23, 2008.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    I recently began to like B&W film. I would like to shoot more, but absolutely won't if I can't get any bigger pictures!
    Problem: no decent labs within 2 hours.
    Solution? Mayyyybe a film scanner? Scan the prints high-res and send them off to Smugmug, etc? An acquaintance recently told me that he has some sort of film scanner that was able to use to get a 40"x40" out of a 35mm and it looked decent. This seems extreme.
    All I want is the ability to make at least 16x20's from my B&W negatives.
    Will a film scanner do the trick? How should I go about this!?
    Please help!
  2. KD5NRH
    KD5NRH TPF Noob!
    Apr 26, 2008
    308
    Stephenville TX
    A 4800dpi scan would just barely give you 16x20@300dpi, so that's doable with fairly inexpensive equipment. The problem with a flatbed will be getting a clean and perfectly focused scan at that res. A dedicated film scanner can do it, or you can look at a flatbed and a good quality fluid mounting kit to keep the negs perfectly flat and allow you to make tiny adjustments in the height above the scanner glass for focus.
    I haven't really printed anything over 8x10 from mine, (Epson 4490) since I only have a Canon Pixma 2600 printer (8.5" width is all it can handle) so you'll have to find someone else to get suggestions on which scanner to use.
    While we're on the subject of bigger prints, has anyone ever tried to trick the Pixma series drivers into using longer paper? I was thinking about cutting down some 11x13 to 8.5x13 and using it to print 8x12s.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I'd actually see if I can mail them to a lab who can do high-res scans.
  4. tirediron
    Jul 8, 2005
    41,108
    12,492
    Victoria, BC
    Darkroom equipment is cheap and plentiful now... buy yourself a medium size Durst or Omega enlarger, a few trays, timer, print-washer and do it yourself. 16x20 is pretty ambitious from a 35mm negative... unless you're shooting 50ASA or lower (and even then...) you're going to have some serious grain to deal with.
  5. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    I used to do 35mm 16x20s, but only with Kodachrome 25 or Panatomic-X (B&W), which of course have not been available for some time now, regrettably.
  6. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    so, you're telling me in this thread that film is supposed to be much better than my 40Ds as far as IQ.
    BUT, now everyone's saying that I actually can't get even a decent 16x20 out of a 35mm frame?
  7. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I would have an 8x10 printed, see how it looks. If you think you could go 4 times larger, mail it off to a lab that can do the 16x20.
  8. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    16x20 is certainly possible with 35mm depending... but IMO, the easiest would be through a traditional darkroom rather than a scan then print.
  9. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    I would never print a 16x20 from a scanned 35mm frame unless it was a drum scan. And I would only do that for color.
  10. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    Makes sense, thanks for explaining. I will limit my film shooting to 8x10s or smaller probably.
  11. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    You can print 16x20, I just wouldn't do it from a scan unless you're prepared to shell out some cash for a drum scan. And I would spot check a smaller print first.
  12. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    ok, thanks. So, when my local lab says "16x20's a little big for our negative scanners" does that mean that all they're doing is scanning them?
16x20 print 35mm
how big can 35mm be enlarged
how much can 35mm be enlarged
