Getting More Grain
Discussion in 'Beyond the Basics' started by jorgeantonystride, Jan 14, 2010.
  1. jorgeantonystride
    jorgeantonystride TPF Noob!
    Jan 14, 2010
    15
    London
    I'm currently trying to get more grain on my images and am using Ilford 3200 Delta 35mm and 120mm B+W in my cameras, but am still not getting sufficient grain. If anyone could provide me with advice on how i can achieve more grain not only on black and white but also colour film, i'd be very grateful.
  2. robertwsimpson
    robertwsimpson No longer a newbie, moving up!
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    take pictures of corn and wheat?
    just kidding, I don't know.
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,319
    14,563
    USA
    I'd try developing in Rodinol if you want an emphatic grainy appearance.
  4. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    When you're developing the film, try using warmer water and really shaking the sh!t out of the developing tank. You can also try diluting the developer more and letting the film sit in the solution longer while still shaking the sh!t out of the developing tank.
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,123
    2,905
    Chesterfield UK
    This is Delta3200 pushed to iso6400
    [​IMG]
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    As Pugs said screwing with the developing can help with it. Also under exposing and over developing (pushing to 6400) could help too, but one of the downsides is that both of these methods have an effect on the tone of the final image.
    Try Kodak Tmax3200. That is one grainy film too.
  7. KenC
    KenC Been spending a lot of time on here!
    Jan 18, 2010
    5,700
    1,472
    Philadelphia
    I second some of the other comments. In my experience developing T-Max 3200 (about ten years ago when I still shot BW film), any developer other than T-Max gave much more grain. I remember D-76 as being pretty bad (good?) in that respect. Of course, as others have pointed out, you lose other things in the process, like shadow detail.
  8. Jay DeFehr
    Jay DeFehr TPF Noob!
    Jan 18, 2010
    15
    Idaho
    Do everything wrong! I'm joking (ok, half-joking), but since the minimization of grain has been a constant struggle for B&W film users and manufacturers since the advent of miniature film, if you simply reverse the conventional wisdom on film exposure and processing, you'll get big grain by default. There seems to be some confusion on this point in then posts above that recommend UNDER exposing your film. This is the opposite of what you want to do. Underexposure/over development is a good recipe for high contrast/ minimum shadow detail, but if one looks at a pushed negative, they almost always look watery thin, especially in the shadows, where there's almost no density. Density is made of grain, so what you want is a high density negative. You can still get a full range of tones in a high density negative, if you develop properly, but it will suffer a loss of sharpness, compromised gradation, and most of all, increased grain. You should also favor a low sulfite developer, like Rodinal, or even a print developer, suitably diluted. Delta 3200 is a low contrast film with a real emulsion speed of around EI 800-1000, so if you were to expose it at EI 400-800, and develop it to your desired contrast in a dilute print developer, You'll see a whole lot of grain. Whether or not you'll like the look of the grain is a personal matter. I personally don't care for the fluffy grain of Delta 3200, but the grain of Tri-X is so classically beautiful, it's almost irresistible. So, to summarize: overexpose, use a low sulfite film developer, or a dilute print developer, and develop to desired contrast. This last point is not as clear cut as it might seem. Over development will undoubtedly increase grain in the negative, compared with underdevelopment, but a dense, low contrast negative printed on a high grade of paper might be a grainier final product. Good luck!
    Jay
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    ... I need to try this. I never thought of that :) Thanks.
black and white more grain
getting more grain from b&w
how do i get more grain in my film pictures
how to get graininess in b&w photos
why develop 3200 film in warmer water
why i am getting lots of grain in my images
