Getting Texture out of Hand Scraped Wood
coopzilla
Oregon
Hey guys, I'm shooting in a makeshift Studio with a Canon EOS 5D, and I need to know if anyone has some tips for bringing out the texture in hand scraped wood. I have some lights and a soft box, but what would you guys suggest?
Basically, the wood has a shiny, finished surface with contours on it, to be specific. Attached is a photo of what I'm trying to do, but failing at.
Thanks,
Evan
For surface texture, you want low angle light as hard as you can stand it, with a bit of high angle light for fill. Grab a couple clamp lights, put a 100W bulb in one and a 20W or less in the other, and play with it until you find your angles.
Yes, texture can be emphasized by using light that crosses the texture. And also, a harder light would also help.
So ditch the softbox and use bare lights. Put the main light to the side of the subject/object and see what you get.
*edit*
If you are trying to see the grain in the wood of a finished piece...then my advice above may not be idea. oops.
