GIMP vs. Photoshop
Discussion in 'Photography Beginners' Forum' started by Abby Rose, Feb 23, 2010.
  1. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    and other similar programs. What is better about photoshop? And if they are the same, then why does anyone bother with photoshop/like programs? Im going to assume they are not the same.
    :scratch:
  2. PhotographyPool
    PhotographyPool TPF Noob!
    Feb 23, 2010
    40
    Photoshop definitely, you will be able to notice the difference
  3. williambarry
    williambarry TPF Noob!
    Jan 26, 2010
    119
    Texas
    Photoshop is more advanced than gimp. The coding is better, the algorithms are better all around it works better (for those that know how to use it). Photoshop is not simple, is not cheap, and isn't worth wasting your money if this is a once in a while hobby for you.
  4. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    Yep, I kind of figured. :) Gimps good enough for me, though.
  5. KmH
    Apr 9, 2009
    40,552
    5,543
    Iowa
    Photoshop Elements is not expensive (about $75). Photoshop CS4 is $700 and CS4 Extended is $1000.
    The problem with both GIMP and Elements is that they can only edit in an 8-bit color depth.
    Raw images are captured at a 12-bit or 14-bit color depth, depending on the camera, and get converted to 16-bit files when they are converted.
    So to use GIMP and Elements the clore transitions are not as smooth and if one isn't careful they can wind up with artifacts like banding and posterization.
    There is a ton more support for Photoshop than there is for GIMP.
    One last thought: An alternative to Photoshop is Corel's Paint Shop Pro (PSP, $100) Photo Editing Software ? Corel PaintShop Photo Pro X3
  6. myfotoguy
    myfotoguy TPF Noob!
    Feb 15, 2010
    855
    Minneapolis, MN, USA
    I second the PS Elements suggestion. Also, if you're looking for an organzer too then ACDSee Pro is aweseom and has powerful editing (yes, I'm a fan I uset it and really like it). Actually, Elments has an organizer function too.
    Lightroom is another good choice, but expensive.
    ACDSee has a basic version that's around $50 (I think).
    Just some more ideas. It can get expensive. If you do end up buying something that is receommended to you, you might (if you haven't thought of it already) see if a demo/trial version is available.
  7. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    I wasnt actually looking for suggestions, but if I do I will know who to ask! :) I just have never used photoshop, and I'm learning about gimp now, so I was curious.
  8. KmH
    Apr 9, 2009
    40,552
    5,543
    Iowa
    My mistake Abby, I'm sorry! I won't try to help you out again.
  9. Abby Rose
    Abby Rose TPF Noob!
    Feb 17, 2010
    642
    Michigan!
    :) kmH, you surely know I dont mind? It was helpful, even if I'm not buying anything.
  10. tdiprincess
    tdiprincess TPF Noob!
    Feb 12, 2010
    153
    Buffalo
    Learn gimp and then move up to PS.. kinda like photography... We start out noobie and silly and slowly move up :)
  11. CNCO
    CNCO TPF Noob!
    Feb 4, 2010
    488
    7
    USA
    I could be wrong but gimp does not support RAW format. I am not sure about elements.
