- Joined
- May 1, 2008
- Messages
- 25,422
- Reaction score
- 5,001
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
Gah this new lens leaves me feeling like a newb to photography again!
Ok so these are partly grabshots of a little bug who wandered into my room (and out again). Sadly not a single green or leafy thing to place him upon so its the edge of a little petri dish that I had him (mostly) crawling in - however he was far to warm and active a bug to sit still in any one place for long and he was off again in seconds.
The high mobility and magnification factor meant that I couldn't have the flashlight directly overhead (ie doing one handed macro) which has sadly meant that I've got photos with a very harsh direction to the lighting. This is becoming a problem as the shots below show with not just shadowed, but harshly shadowed areas of the insect showing.
Note that I was only using f10 because I was working at around 3:1 macro and thus if I had used a smaller aperture for more depth I would have lost out on sharpness due to diffraction.
http://farm5.static.flickr.com/4036/4366649284_5d1e7685c3_o.jpg
f10, ISO 100, 1/200sec - flash used
Probably the only shot that really has a half decent composition to it, even though the upper areas still have a lot of empty dead space to them.
http://farm5.static.flickr.com/4030/4366648962_66bd85c7fa_o.jpg
Lighting is not as harsh, the insect and flash having a better angle on each other (for once). However whilst the magnification is good the resulting image has an untidy crop to it - with parts of the insect missing in an undesirable manner. Focus and magnification "zoom" on this lens is all controled by the focus wheel - however I have to get used to balancing focusing, magnifiaction control, frame content and also retaining the correct distance for the focus from the subject (ie maintaining correct focus and thus a sharp shot)
http://farm3.static.flickr.com/2760/4365903123_74d4c3148f_o.jpg
Harsh lighting (I had to dual process the shot so that the back was suitably exposed instead of overly white from the flashlight) and not really a composition that says anything.
So there you go - have at them!
Any comments/crits/advice welcome thank you
