Going digital, can I use my old lenses?
Discussion in 'Photography Equipment & Products' started by AnnaR, Sep 4, 2005.
  1. AnnaR
    AnnaR TPF Noob!
    Sep 4, 2005
    I have finally decided to buy a digital camera, and my knowledge on the subject is pretty limited. I have been taking photographs with an old Minolta XD 5, and I have a complete set of lenses in great condition. My question is, can I use these on a digital (minolta) camera, and if yes, can anyone recommend any specific cameras?
    I'd love to hear any input on the subject!
  2. D70Mike
    D70Mike TPF Noob!
    Aug 21, 2005
    9
    Birmingham
    As far as I know, lenses are nearly always interchangeable between a manufacturers SLR and D-SLR cameras, so you shouldn't have any problems.
    The only thing you have to consider though is that because of the size of the CCD in a digital camera, the focal length is 1.5x larger than on a 35mm film camera. This means that if say you have a 200mm lense the effective focal length will be 300mm which is great if you want the extended range, but not so great if you're a landscape photographer as you will be loosing some of range of a shorter lense.
  3. Xmetal
    Xmetal TPF Noob!
    Nov 22, 2004
    2,351
    29
    Newcastle, Australia
    If they are full manual lenses then I believe you can't use them with the Digital body.
  4. APHPHOTO
    APHPHOTO TPF Noob!
    Dec 24, 2011
    150
    9
    JC New York
    Im not sure about Minolta, But as far as Canon users. If you own a EOS than older lenses wont fit the body.
  5. MLeeK
    MLeeK TPF Noob!
    Oct 20, 2011
    6,761
    1,379
    NY
    If they are A mount Minolta lenses they will work on sony cameras.
    Unfortunately, I believe the Minolta XD5 is MD mount. It's considerably older.
  6. MLeeK
    MLeeK TPF Noob!
    Oct 20, 2011
    6,761
    1,379
    NY
    Many of Nikon's film lenses are all compatible with today's digital SLR's.
    Film EOS mount canon lenses will work with canon Digital. FD mount canon lenses won't work with digital without and adapter and I believe then they are only full manual focus and aperture.
    There are adapters for just about everything out there. Chances are you can find one to adapt the lenses, but you may not have any auto anything to them.
  7. unpopular
    unpopular Been spending a lot of time on here!
    May 17, 2011
    9,424
    1,972
    Montana
    It is an MD body. You could try using an adapter, but from my experience the glassed adapters aren't very good, at least not without stopping down considerably. You can get some cool effects wide open, but for general use, no.
    Stopped down, they do work pretty well.
    An NEX or micro-4/3 camera will work much better since they don't need the correction glass to operate. But it should also be pointed out that these lenses will be useable only in full manual, no AE, no auto aperture and you must "stop down" to meter since the camera doesn't know what the lens is doing. Working this way has it's advantages, it forces you to slow down and work in manual mode, but for many photographers the disadvantages vastly outweigh the advantages.
  8. DaveO
    DaveO TPF Noob!
    Nov 30, 2010
    14
    Crossville, Tn
    If you get an adapter for Nikon, The higher end digital cameras will work ( meter ), I think the D90 and higher. I don/t know about autofocus though. Just about any digital camera will work with an adapter, but they may not meter. You can always use a hand held meter with them.
    DaveO
  9. Kerbouchard
    Kerbouchard TPF Noob!
    Apr 1, 2010
    2,697
    575
    DFW
    I'm pretty sure in the last 6 years or so, the OP probably figured it out...
  10. SCraig
    SCraig Been spending a lot of time on here!
    Nov 12, 2011
    6,294
    2,343
    Nashville, TN
    Deleted .. Didn't notice it was a 6 year old post ;(
  11. unpopular
    May 17, 2011
    9,424
    1,972
    Montana
    that would explain the Minolta DSLR...
how to use minolta xd5
which slr digital camera will take the old lens from a minolta xd5
